Old 03-07-2006, 10:06 PM   #1
NitroMike
Active Member
NitroMike's Avatar
Trailing arm bushings, help!
I got the bolts out of the crossmember that hold the trailing arms with only a minor struggle, or should I say a good breaker bar with a 4' pipe hung on the end, but now am wondering the best way to get the old bushings out of the front of the trailing arms while they are still on the truck. Heat and sledge persuasion? Or a big c-clamp as a homemade press?
The older I get, the faster I was!!
NitroMike is offline   Reply With Quote
Old 03-07-2006, 11:19 PM   #2
kelsfine69
18 Till I Die
kelsfine69's Avatar
Re: Trailing arm bushings, help!
I have been pondering this question for 4 months now. From the advice I have seen on the board the worst part is over. Take a torch and heat them up till they fall out, warning quite smoky. You could drill with a small drill bit all around and then just pry them out. I have new Poly bushings on my bench from Energy Suspensions, just waiting for the weather to warm up. Hope this helps.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-07-2006, 11:35 PM   #3
smbrouss70
smbrouss70's Avatar
When I did mine, the trailing arms were completely removed from the truck. I just set them on fire with the torch, comes out real easy after that. To put the new Poly bushings in, I put them in the freezer for a few hours, and right before I put them in, I heated the trailing arms up, and they slipped right in. I know it doesn't help much if you're trying to do it IN the truck, but that's what I did.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-08-2006, 09:11 AM   #4
68jimmy
68jimmy's Avatar
That's the approach I took when I did mine... Made things much easier! Good luck.
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 03-08-2006, 02:45 PM   #5
junkyardjohn
junkyardjohn's Avatar
I TOOK MINE ALL THE WAY OUT OF THE TRUCK ALSO. I CHEATED. I TOOK MY TRAILING ARMS, NEW BUSHINGS & A 6 PACK DOWN TO THE LOCAL DRIVE LINE SHOP. HE HAD THE OLD ONES PRESSED OUT & THE NEW ONES PRESSED IN BEFORE I COULD FINISH A BEER. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-08-2006, 09:10 PM   #6
shade67
I did the set'em on fire routine! Very smokey let the neighbors know what you are up to- at least about the amount of smoke! My neighbor came over to see if I needed the fire dept! my urethane bush slid in with no problem after the fridge treatment and the lube!
Scott
66 chevy short step 327 4speed
67 chevy Short Fleet tpi 350 700r4
72 chevy K10 swb
01 GMC Sierra
01 Pontiac Bonneville
shade67 is offline   Reply With Quote
Old 03-08-2006, 12:12 AM   #7
da-burb
"Ochre Ogre"
da-burb's Avatar
Burn them out. To replace them I have heard you can warm the trailing arms up and freeze the bushings.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 03-08-2006, 08:39 AM   #8
Joe67
67 is sold
I removed my trailing arms, torched the old ones and used a few taps of the hammer to remove them.
REMEMBER TO NOT DESTROY THE INNER SLEEVE, often you need to reuse them.
When I installed my poly PST bushings, they went right in
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-09-2006, 12:26 AM   #9
AKChevyman
Chevy Forever
AKChevyman's Avatar
It took me about 30 mins using the drill method the installation was a little bit harder since I didn't have a torch to heat up the arms but with a bench vise and 2 flat things of steel they went in pretty easy. Just my .02 good luck
My first love
1971 C20
Hugger orange
Getting face lift and heart transplant .30 402 BB /TH400 and GV
Wifes car
1969 Chevelle SS 396 325hp/TH400
Factroy A/C Automatic w/ Floor shift console.
restored.
AKChevyman is offline   Reply With Quote
Old 03-18-2006, 08:46 AM   #10
NitroMike
Active Member
NitroMike's Avatar
I ended up making a simple puller (actually a pusher) from one of my balancer pullers and some flat steel. You can use an impact gun to speed up the process and do the work while the trailing arms are on your truck.
I'll post pictures if anyone is interested.
Old 03-18-2006, 03:48 PM   #11
1969burb
when i did mine i used an eighth inch or so drill bit and drilled as many holes around the inner sleeve as i could, then used a jigsaw with a metal blade to cut the old bushing along the holes i had drilled. once you have cut all the way around the bushing push the inner sleeve out and the remaining old bushing peels out pretty easily. I have a torch but hate breathing nasty fumes unless its really necessary!
1969burb is offline   Reply With Quote
Old 03-19-2006, 05:14 AM   #12
4x4Poet
1969burb, I did the burn method, but I like your meticulous approach.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 03-19-2006, 01:26 PM   #13
Green Machine
Green Machine's Avatar
I've done the burn trick and then used the poly bushings before. If I was going to put in new originals I would take the arms or whole truck to a shop and let someone else press them in. On our current project, we just inspected them and left them alone, unless they are relly shot and loose, a few cracks around the outside really don't hurt anything, if they go bad, I'm just going to take the whole truck to a shop and let someone else deal with it. I know its hard not to replace some marginal parts when you are right there, but sometimes leaving things alone is a lot cheaper and easier, and may be actually the best way to go. Just my 2 cents.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
