Old 03-10-2006, 09:47 AM   #1
Draggin79
Draggin79's Avatar
20" rims on 79 chevy BS questions
Hey guys, I am getting ready to order a set of rims for the 79. Its gonna be bagged w/ 1.5" c-member drop. I want a set of 20" Panther Juice 5's. I plan on running a 40 series tire.
Just wondering what specs you guys used when getting ur rims/tires without rubbing anything.
I already know I cant use inner fenderwells, and i have to cut my rear wheelwells out. anything else ill need to get rid of in order to run 20's front and back?
Draggin79 is offline   Reply With Quote
Old 03-10-2006, 09:48 AM   #2
Draggin79
Draggin79's Avatar
Re: 20" rims on 79 chevy BS questions
Old 03-10-2006, 12:57 PM   #3
Jebb1978
Jebb1978's Avatar
Ken is running 20's and his truck isn't cut at all. Ken, Ken can you help this man please?
See if this link helps you at all.
http://www.imagestation.com/album/?id=4290400437
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 03-10-2006, 07:47 PM   #4
Draggin79
Draggin79's Avatar
ttt
Old 03-10-2006, 08:20 PM   #5
SCOTI
SCOTI's Avatar
It all depends on what you're attempting to do.
Kens truck has 20x8's up front w/5.25bs & 245/40's. The lower arms are trimmed to prevent unwanted scraping & he has the stock size inner fenderwells. On the back, he has 20x9.5's w/either 4.5 or 5" bs (I can't remember 100% which one it was) & 295/40's. The rears required no mods to fit.
These sizes fit w/o issue because Ken isn't trying to plant his framerails. They work for the way the truck is designed. If your plan is to plant the rails, a different bs will possibly be required.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-10-2006, 10:05 PM   #6
Draggin79
Draggin79's Avatar
Yea, I am definetly planning on planting the framerails on the ground.
Old 03-10-2006, 11:23 PM   #7
SCOTI
SCOTI's Avatar
The fronts should still be ok w/the inner wells removed.
I would say you'll need more back spacing & mini-tubs on the rears unless you cut out the inner wall of the bedside for clearance. One suggestion.... keep a close eye that you don't get overly aggressive on the rear bs & wind up w/the front track width visibly wider than the rear (a major no-no in the custom/slammed truck scene IMO).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-12-2006, 10:13 PM   #8
Draggin79
Draggin79's Avatar
Im still stuck on the backspacing, its kinda hard to do with a bare frame, and none of the suspension bolted up :P
Old 03-12-2006, 10:45 PM   #9
SCOTI
SCOTI's Avatar
If it were me, I would wait until I had something to base facts on. It sucks.... but sometimes it pays to be patient.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-12-2006, 10:51 PM   #10
Draggin79
Draggin79's Avatar
ya my dad keeps tellin me we need the rims to set the suspension up tho :P I guess ride height and all.
Old 03-13-2006, 02:19 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
If that's the concern then decide what size tire you plan to run. Take a look here for a conversion chart that allows you to get the outside diameter of the tire. http://www.4lo.com/ Use a set of beater tires and wheels that are the same height that you plan to run.
I suggest this because it doesn't sound like this project will be done in the next few months. By then you may look at those wheels and have a different opinion of how they look.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
