Old 03-18-2006, 10:34 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
axel swaps
What years of axels will fit on a 67-72? I would like to swap one out so I can have 3.73 ratio and a wider stance.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 03-18-2006, 11:14 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: axel swaps
Depends if you want 6 or 5 lugs but I take you are asking what years rear differential housings will work on a 65-72 2wd.... 73 up have leaf springs instead of coils. 71-72 are 3/4" wider on each side and are 5 lug. Most likely a 65-72 with a manual trans had 3.73 gearing. Many can be modified/fabricated to work.
dennislbrooks is offline   Reply With Quote
Old 05-07-2006, 11:52 AM   #3
JayDubBlazer
go cyclones
Re: axel swaps
I just want the wider axel with a 3.73 ratio
Wes
PROJECT OLE GREEN
2017 Silverado LT
Old 05-07-2006, 12:02 PM   #4
krue
Designated A-hole!
krue's Avatar
Re: axel swaps
If your talking about your 72, the 73+ rears are the same width.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 05-07-2006, 03:55 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: axel swaps
there are no easy swaps to get wider than your 72's rear.
GM claims to have done that intentionally (front track width wider than rear) but most say i't BS. Even if you look on more modern trucks, it's the same way.
You could get rims with less back spacing...a deeper dish if you will. That'll place the tires out further.
Old 05-09-2006, 06:34 PM   #6
cell
Active Member
cell's Avatar
Re: axel swaps
are the 73+ rears the same width as a 67? I have been thinking about buying some coil spring seats to have welded onto a 73+ rear...
cell is offline   Reply With Quote
Old 05-09-2006, 07:01 PM   #7
dennislbrooks
Re: axel swaps
3/4" wider on each side---this is a plus ----10" wide wheels with 4" backspacing are near perfect
