driveline shudder's after lowering
just lowered my truck as some of you know i posted some pics,it turned out good,however,i have a shudder now when taking off from a stop,but it smooths out at speed.it's got a carrier bearing set up which i think is causing some angle issue's,my question is can you have a one piece made up,or is there a cheaper way to go.by the way why a carrier on a shorty?
Re: driveline shudder's after lowering
pinion angle is probably the problem. When you lowered it did you use any shims under the axle mounts.
I have seen both styles of drive shafts, my thought would be the single shaft just because of simpilcity. |
