Old 03-19-2006, 06:37 PM   #1
Ironhorse
Ironhorse's Avatar
Suburban Bumper Guards ?
I have a '91 1/2T 4x4 'Burb with the black center wrap or trim piece mounted to the front bumper. It has some sort of short black bumper guards that seem made of the same poly/plastic/vinyl ? I have seen other 'Burbs of that age with the taller chrome guards with the rubber strip in the center. Is one style an option over the other? I like the taller style, just seems to look better in my opinion. Anyone have an idea where I can get a decent pair. Have looked at several 'Burbs in local yards with no luck. How differ in the mounting and if I find a pair at a swap meet, anyone have a pic of the contour so I will know they fit correctly.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 03-22-2006, 11:45 AM   #2
aggiedave98
Re: Suburban Bumper Guards ?
take a look at lmctruck.com (and get a catalog from them)... a great source to see what came on different years even if you don't buy from them...
aggiedave98 is offline   Reply With Quote
Old 03-22-2006, 09:33 PM   #3
screwballl
Tonawanda 454
screwballl's Avatar
mine has this style (my burb)
heres the other style you're talking about i believe:
If I remember correctly, the ogre jaw type (the large chrome with rubber in center, 2nd pic) was last seen on the 89-90 burbs and most 90-91s that I have seen all have had the trim only or trim plus block guards (1st pic).
Looking at LMC now, says for the chrome type will work for 81-89 and rubber type for 90-91.... but as they use the same mounts and bumpers have the holes already, I would assume that either could be used. The small type only uses a single bolt through the bumper and the chrome type uses 2 per guard.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 03-24-2006, 06:10 PM   #4
Ironhorse
Ironhorse's Avatar
Thanks for the info on the bumper guards. The taller pair on the tan 'Burb is the ones I am looking for. Must be a pair in a local yard somewhere. Do you know, does the black bumper strip need to be cut or do the taller 'guards mount over the strip to the bumper? Perhaps the center strip is divided to accept the 'guards? Will look a bit further.
Wellington, Ks
Old 03-24-2006, 06:26 PM   #5
aggiedave98
btw, my '89 doesn't have the "verticle" bumper guards... just the bumper and the black molding stuff...
Old 03-26-2006, 10:28 AM   #6
Ironhorse,yes the strip will need cut.The chrome ones are pre-88.The short black ones,88-up to match the new style trucks.You may be able to get the guards from the dealer still.They will either have notched bumper guards for w/moulding or moulding for w/bumper guards.
Old 03-29-2006, 01:36 PM   #7
Hobbs
Iron Horse,
I have ordered a push bar for the tan burb. I believe that I will have to remove the vertical bumper guards to install.
Would be happy to send them to you for what every it cost to ship.
Will let you know.
Hobbs
Hobbs is offline   Reply With Quote
Old 03-29-2006, 11:49 PM   #8
Ironhorse
Ironhorse's Avatar
Hobbs, Thanks much for the offer. Would be very interested in the bumper guards. Keep me in mind and let me know when you install your push bar. I just think the taller guards look better than the shorter style.
Wellington, Ks
Old 04-01-2006, 11:35 PM   #9
screwballl
Tonawanda 454
screwballl's Avatar
I prefer the larger types myself as well, they looked good on my 76 GMC truck...
Old 04-02-2006, 09:13 PM   #10
Hobbs
Ironhorse.
Have taken the bumper guard off. Will be happy to send them to you for cost of shipping if you still want them. PM me your address, and I will send. Will let you know the cost and you can forward a check after you receive.
Hobbs.
Old 04-03-2006, 05:27 AM   #11
Ironhorse
Ironhorse's Avatar
Hobbs, PM sent with address. Thanks.
Wellington, Ks
Old 04-05-2006, 07:58 PM   #12
Hobbs
Ironhorse...
Bumper guards have left Ala. headed your way. I have PM some info.
Hobbs.
Hobbs
1988 sub. 3/4 ton 2wd 454.
BFG 295/75/16 on American Racing 16x8
