03-22-2006, 09:59 AM | #1 |
87 Wanna Be K30
2WD 14ff Rear....
Do any of you know if a 79 c20 14ff rear from a 2wd pickup will be the same width and if the spring perches will be in the same spot as a 4wd truck? so basically what im trying to ask is if the rear will just swap into an 86 K20. Yes, No, Maybe? And what about the rear leaf springs... are they the same? Thanks alot guys
-Scott |
03-22-2006, 12:31 PM | #2 |
Professional Grade
Re: 2WD 14ff Rear....
Should be a bolt up!
Measure the width of the perches before you buy it though, just to make sure.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
03-22-2006, 01:57 PM | #3 |
87 Wanna Be K30
even the leaf springs should bolt up?
03-22-2006, 02:56 PM | #4 |
Look closely at the shock mounts. I believe that there is a difference between the 2wd and 4wd.
03-22-2006, 04:07 PM | #5 | |
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
03-22-2006, 04:06 PM | #6 |
Professional Grade
My 2wd and 4x4 frames had the same shocks, less length.
The 4x4 springs may be longer than the 2wd, but if you unbolt the u-bolts instead of the springs, your new diff should bolt directly to the new 4x4 springs.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 03-22-2006 at 04:06 PM. |
