Old 03-27-2006, 08:07 PM   #1
chevyboy55
chevyboy55's Avatar
Junction Block
I am wiring up power door locks & alarm system in a 72. There will be about 4 different items that need power. I was thinking of putting a junction block behind the seat on the floor(gas tank is not in the cab it has a blazer tank w/ sidemarker fill) What I am after is not having a bunch of wires running to the engine compt. Does any one have ideas & or pics? Mike
chevyboy55 is offline   Reply With Quote
Old 03-27-2006, 08:59 PM   #2
qksilver
Re: Junction Block
Why not put one on the inside of the firewall under the dash. You would be running the wires thru the front door jams anyway but wouldn't have to run wires back and forth from the back of the cab
qksilver is offline   Reply With Quote
Old 03-27-2006, 09:28 PM   #3
chevyboy55
chevyboy55's Avatar
Re: Junction Block
The power door lock wire loom & relay is under the dash & there is not alot of room left for the alarm control box,shock sensor,valet switch,starter kill relay etc.
Old 03-27-2006, 11:08 PM   #4
qksilver
Re: Junction Block
good reason.....
Old 03-27-2006, 11:26 PM   #5
Jayss109
Active Member
Jayss109's Avatar
Re: Junction Block
I used a junction box that I believe is used for computers. has two rows of screws, which one screw "junctions" with the screw in the opposite row. What I did was take all the screws off, lay a wire along the center, then solder at each intersection making all the screws "hot". Heres a couple of pictures from radio shak, excatly what I used.
Jason
________
Fix ps3
Jayss109 is offline   Reply With Quote
Old 03-28-2006, 04:42 AM   #6
Lippyp
English Chevy Owner
Lippyp's Avatar
Re: Junction Block
Car audio places sell some good power distribution stuff all the way up to 0 gauge, might be a good place to look. This is a uk site but it gives you an idea of what to look for http://www.caraudiodirect.co.uk/inde...cPath=73_56_62
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
