constant power fuse
is there one on the fuse block? i need power with key on acc, off, and run for my radio to keep the memory (clock and pre-sets).
or should i run a wire to the battery with a 20 amp inline fuse? |
A little east of nowhere
Re: constant power fuse
I don't think these trucks had a takeoff in the fuse box for constant power. The only power out with the key in the acc/off/run positions is lights, cig lighter & 4way flasher? Why not tee in to the cig lighter power?
68 C10 250 4spd 69 C20 327 4spd 69 910 250 3spd 80 K10 350 4spd 76 C60 366 5spd school bus "THERE'S NOTHING YOU CAN BREAK THAT SOMEONE CAN'T BE PAID TO REPAIR" |
I pretty sure the cigar lighter tap on the fuse block is hot all times. the other point would be at the top of the block just below the fuel gauge tap, it should have a pigtail connected to it.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
hmm, you guys were right, the cigarette lighter and the plug under the fuel gauge have constant power. thanks i got it all figured out now.
Matt - Does that stay hot during crank? It MAY shut off during the starter cranking mode. Just check before you go too far.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
#6 | |
