04-02-2006, 04:54 PM | #1 |
DJM 3" Lower Control Arms
Soon I will be lowering my truck more then it currently is. I purchased a set of DJM lower control arms and I am thinking they may sit very close to the ground. I currently have 2" lowering spindles and I cut my springs about an inch. Any one have them installed? Any issues with ground clearance? Any pictures? Thanks
Joe
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
04-03-2006, 07:04 PM | #2 |
www.73-87chevytrucks.com
Re: DJM 3" Lower Control Arms
Are you going to be using the spindles AND the LCA's together? I woudn't recommend that.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
04-03-2006, 07:20 PM | #3 |
I was planning on it. What problems would I run into? I am looking for about a 5 inch drop in the front. What would be the best combo for that?
04-03-2006, 07:25 PM | #4 |
Hollister Road Co.
I did the same thing and the A arms drag the ground. You would have to run 20's on the front to keep it from dragging.
04-03-2006, 07:51 PM | #5 |
So dwcsr, you have lowering lower control arms and drop spindles and that resulted in ground clearance issues? I am running 17s and I don't really want to go any bigger than that.
04-04-2006, 01:57 AM | #6 | |
Hollister Road Co.
04-03-2006, 09:38 PM | #7 |
Well I did some more research and it appears that if I want to lower my truck 5 " in the front and use the 3" lower control arms I should use the stock spindles with some lowering springs. That is what DJM has as one of there kits. Thanks for the heads up.
04-03-2006, 11:25 PM | #8 |
Using those components together violates Scrub. Another words, you get a flat and you loose control since the control arms hang below the rim.
Spindles and LCA's are not designed to be used together. You need a 3" drop spring, or 3" spindles and 2" springs.
04-04-2006, 01:59 AM | #9 | |
Hollister Road Co.
04-04-2006, 02:20 AM | #10 | |
Until Seventy Times Seven
Like Chris said, using both dropped spindles and dropped arms are not recommended. (I don't even think 20s couldn't give you enough of a scrub line with the dropped spindle/arm combo.)
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 04-04-2006 at 02:26 AM. |
04-05-2006, 06:00 PM | #11 | ||
04-05-2006, 05:38 PM | #12 |
not trying to hijak, but would just the 3" LCA be ok with 15's?
80 Chevy K10 350/350turbo 86 Chevy 1/2 ton shorty project truck 79 Chevy 1/2ton 350/350turbo not much to look at... ***Retired*** 97 Chevy C1500 4.3/5 speed.....daily driver |
