04-03-2006, 05:53 PM | #1 |
The LuvShack Garage
Question About Blazer Tops
Borrowed this pic from Randy (Teeitup) over on the parts board, someone
else asked this same question and Randy answered it I think, I just want to make sure because I am switching the tops on my two blazers and the single wall top will be put on "GQ" so ? is are the caps the same for each of the tops? or are they different like Randy said? and which one is which?
04-03-2006, 08:14 PM | #2 |
Member since 2000
Re: Question About Blazer Tops
i think the differents caps are from different year blazers. I'm sure the smooth one are for 69-70.
04-03-2006, 09:18 PM | #3 |
Active Member
I agree, I just popped two sets of these, one off of a set of 69 doors (smooth and like the ones on the left in the picture) and the ones on the right are just like the set I removed from my 72 doors.
04-03-2006, 09:29 PM | #4 |
Agreed. My 70 have smooth my 71 ridges. My 70 doesn't even have the drip edges on it. Never has had them on it
04-03-2006, 10:15 PM | #5 |
The Blazer King
MOst of the ones i've personally seen had the grooves in them and most of the Blazers i've owned have been 71/72's. I'm sure they are NOT top specific.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
04-03-2006, 11:12 PM | #6 |
Just like to part out trucks!!
I'm not sure on these, both sets came off 71-72 blazers, one was a double wall. But who knows they could of been changed out, or different doors put on it too. The smooth set if the first set I've ever came up with, most are the grooved ones. I've never had a 69-70 blazer to part out to check and see. It would make sense to me if they were 69 or 70.
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
04-04-2006, 04:59 AM | #7 |
Mine is a 71 double wall and has the ones with the ridges.
04-04-2006, 06:30 AM | #8 |
Wasn't the drip rail a later addition to try and keep water running out of the door?
04-04-2006, 07:02 AM | #9 |
My '70 has a double wall, and no ridges.
Tim |
04-04-2006, 08:00 AM | #10 |
I miss this truck.
Do one style or the other work better for keeping water out?
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
04-04-2006, 04:28 PM | #11 | |
The LuvShack Garage
Good question, I wish someone here would answer this also
04-04-2006, 07:25 PM | #12 |
Member since 2000
well my brain come up with is
I'm sure will the flat piece it will/can create pockets between itself and the rubber, there are no precise machined parts. The grooves IMO on the other set are made to put pressure on the rubber so if water some how gets in between there it acts like a barrier with the rubber. there use to be these plastic piece........maybe someone can post. but they screwed onto the top of the door or top windshield frame and they help channel water. |
04-04-2006, 07:23 PM | #13 |
Not a bad nut after all..
My '71 Blazer:
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
04-04-2006, 09:05 PM | #14 |
PROJECT 7DEUCE
My 72 with double wall top has the ridges...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-05-2006, 09:42 PM | #15 |
Back in the sticks
69 Double wall, no ridges. Matter of fact, only one door has a cap. The other is flush metal at the top Wonder if the door was replaced at some point....
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
04-06-2006, 10:58 AM | #16 |
I also have a question what is the diff from 69-72 blazer tops and 73-75 blazer tops a guy a worked with says he has a top for my 71 but he has a 73 and a 74 blazer will a see the diff or are they close. THANKS
04-06-2006, 11:48 AM | #17 | |
The Blazer King
Wouldn't interchange if that was your question. WAY different.
04-06-2006, 01:26 PM | #18 |
I asked because i'm going to go get it this weekend. But if it is not the right top i dont want to bring it home. So could you give me some ID tips and some pic would be nice. THANKS
04-06-2006, 04:04 PM | #19 |
The Blazer King
this is a 73-75. Note there is no rear hatch as the glass rolls down into the tail-gate. It would have a track for the glass.
http://cgi.ebay.com/ebaymotors/chevy...52854743QQrdZ1
04-06-2006, 10:54 PM | #20 |
72 with single wall had groves but it was a earlly 72 it might just be a mid 71 thing or like you said its been 30 years who knows it they have been changed at one point but i do know this mine are original i bought this truck from the original owner and the only thing that had been changed was a rod bearing
72 cst 2wd blazer sb soon to have tilt manual 72 gmc swb fleet 2wd bb air tilt auto 93 c/3500 crew-cab dually 03 chevy suburban LT quadrasteer c/2500 4x4 |
04-07-2006, 01:23 PM | #21 |
Thanks 2wdblazer for the help. I should of know that
