Old 04-04-2006, 04:26 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Unhappy How the &@#! do you install the front rubber bumpers in the A-arms?
First of all, I made the mistake of not putting them in BEFORE I installed the front end. Now that I realized I left them out, I am going through all the skin I have left trying to get then dern things in.
Any suggestions on how to get them in, both upper and lower, without having to pull the spindle and spring??
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-04-2006, 05:53 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: How the &@#! do you install the front rubber bumpers in the A-arms?
I have warmed them in the microwave to soften them enough so that they pop in easier. Ten seconds or so is all it takes.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-04-2006, 05:59 PM   #3
glock35ipsc
Thanks TX, I'll give that a try. Getting tired of losing skin on my knuckles! But I'm just glad to be working on this thing again. It was getting lonely!
Bob
Old 04-04-2006, 07:04 PM   #4
SCOTI
SCOTI's Avatar
I tried TX's method but wasn't successful.
What I did was drill a hole on the front side of the bracket that holds the bump-stop to be able to get a grip on the bottom of the rubber using some needle-nose pliers.
I lubed the bracket w/some dishwashing soap & pushed down on the top while pulling w/the pliers. They popped right in.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-04-2006, 07:07 PM   #5
71swb4x4
71swb4x4's Avatar
I have heard that freezing them makes them slightly smaller. Most materials contract when cool and expand when warm, except water of course.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-04-2006, 09:45 PM   #6
jamesi20
jamesi20's Avatar
I used wd-40 on mine and they went in pretty good
jamesi20 is offline   Reply With Quote
Old 04-04-2006, 09:49 PM   #7
qksilver
sometimes when you freeze rubber it will be brittle, so it is easier to rip or crack it
qksilver is offline   Reply With Quote
Old 04-05-2006, 12:07 AM   #8
Green Machine
Green Machine's Avatar
I never did get my new repop lower bumpers in, may be they were made a little off, I ended up putting the old ones back in, they were a little loose, but they fit. I even cut a block of 2x4 to wedge between the frame and the bumper, jacking the front to compress the crap out of it, used all kinds of lube, but no go. I just gave up after so many hours wasted on something so simple.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-05-2006, 12:10 AM   #9
glock35ipsc
Thanks for all the suggestions! Maybe I'll try a little heat and some grease!?
Bob
Old 04-05-2006, 12:50 AM   #10
rkarr
rkarr's Avatar
Dishsoap worked great for me.
Avatar is a pic of "Before"... Just wait..
1969 Fleetside:
Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans.
20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit).
Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all
Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!!
rkarr is offline   Reply With Quote
Old 04-05-2006, 12:26 AM   #11
71swb4x4
71swb4x4's Avatar
If all else fails give the freezer a try. It won't hurt them. If it did we would all (or all of us up North) be in trouble during the winter
Here's an article at Engineers Edge that mentions the freezer trick.
http://www.engineersedge.com/bearing..._press_fit.htm
Here's a thread on Yesterday's Tractor that mentions the same trick.
http://www.ytmag.com/crawlers/messages/32879.html
Old 04-05-2006, 01:52 AM   #12
4x4Poet
Silicone lube is the best lube for inserting rubber in confined spaces or holes. Paste or spray, it's slippier than soap. Harmless to rubber, too, unlike petroleum based lubes.
I would think that freezing would add stiffness making insertion difficult.
Clean jokes only, please.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
