04-08-2006, 10:25 PM | #1 |
Oilfield Trash
Charging System Not Charging
Fired up the old camper special for the first time this spring(been sleeping in the barn all winter) when i hooked up the battery it sparked even though there was nothing turned on in the truck (key off battery drain???) and it also was not charging after i started the engine. The PO converted to the new style alternator, so mabye he didn't have it wired up right? Any suggestions?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
04-08-2006, 10:38 PM | #2 |
Re: Charging System Not Charging
Check here:
http://www.madelectrical.com/index.shtml
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
04-08-2006, 11:03 PM | #3 |
If the PO left the voltage regulator hooked up and its gone bad I think it can cause the battery to drain you might wanna check that.
04-08-2006, 11:28 PM | #4 |
You know... If there was a credit card attached to it, i'm sure my ex could make it charge....
Avatar is a pic of "Before"... Just wait.. ---------------- 1969 Fleetside: Shortened frame for SWB, ECE 4-6 drop. ECE SS tank. All new ECE suspension. Rebuilt 12 bolt 3:73 with Eaton Posi. Front and rear disc brakes. Ramjet 350 and 700r-4 trans. 20" Centerline wheels with Kumho 295/45/20 tires (I hope they fit). Progress pics: http://s44.photobucket.com/albums/f2...uck/?start=all ---------------- Seriously... It's nothing a large dose of cash can't fix... Right? After all, I can't take it with me when I go... Just gotta have enough to get there!!! |
04-09-2006, 01:03 AM | #5 |
Msgt USAF Ret
Are you certain there wasn't a dome light or headlight switch on?
Check out this site for a good reference on the alternator conversion. http://www.chevelles.com/techref/tecref14.html
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
04-09-2006, 01:06 PM | #6 |
Oilfield Trash
I think it is the regulator, it "clicks" when i hook the battery up, I also spotted a bunch of bare wires in the underhood harness, probably just gonna swap out the whole harness with another one i have that i know works.
