04-10-2006, 07:46 PM | #1 |
Draining gas from the tank?
I just found this site a couple days ago, it seems like there's a lot of knowledge here. I was wondering if anyone knows the best way to drain 5 year old gas from the tank, without removing it from the truck. Removing it seems like the only way to me.
Thanks, Jeff |
04-10-2006, 08:12 PM | #2 |
Re: Draining gas from the tank?
Siphon into a can.
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
04-10-2006, 08:26 PM | #3 |
Active Member
cant you just pour new gas in, and it cleans and changes the old stuff?
i've heard this before but dont know the truth!
S.h.i.t happens when you party naked. |
04-10-2006, 10:44 PM | #4 | |
Nothings as cool as my 72
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. |
04-10-2006, 08:28 PM | #5 |
drill a hole,drain it out,and patch it up
04-10-2006, 08:59 PM | #6 |
New Member
Just did this last week. I used a clear hose to siphon tank. The hose was 1/2" dia. from hd. I attached the hose to a small piece of wood with a plastic cable tie.. The wood was about .75"x1"x4'. I used this to hold the hose to the bottom of the tank. Once drained I added about a gallon of fresh gas. The truck fired up and ran well considering it had been sitting for a year.
1968 SWB Fleetside ~In Progress~ Plans: Disc Swap 454 Turbo 400 Lots of body work!! 2004 Victory Vegas Arlen Ness (My Bike) I guess you could say this is my second childhood. |
04-10-2006, 10:14 PM | #7 |
Good idea, I couldn't figure out how to keep a siphon hose on the bottom of tank. I'll try your suggestion.
Thanks |
04-10-2006, 09:11 PM | #8 |
Cantankerous Geezer
Crawl under it and unhook the rubber fuel line. The older trucks had a shutoff valve and a plug for draining. Only problem is that if there is junk in the tank, the strainer won't let it out. Only way to get that out is to pull the tank and flush it.
Fred There is no such thing as too much cam...just not enough engine. |
04-10-2006, 09:16 PM | #9 |
well if the only way to do it is to remove it that isnt hard.Just a few bolts and some manuevering
04-11-2006, 09:25 AM | #10 |
bring it to my neighbor he will get every drop out then burn it in his truck i just drained my burb tank of 15 gal. of ten year old gas gave it to him and he was as giddy as a school girl!
common sense isn't so common anymore |
04-11-2006, 10:07 AM | #11 |
Questionable
if you're not going to buy a siphon tool, just get under the truck and remove the rubber line that jumps the hard line coming out of the tank to the hard line on the framerail (assuming yours has a rubber jumper between). Make sure you have the line pinched off to keep from getting yourself wet
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
04-11-2006, 12:54 PM | #12 |
Designated A-hole!
Sounds like you got an answer, so I'll just say...Welcome to the board from South Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-13-2006, 03:25 AM | #13 | |
04-12-2006, 01:57 PM | #14 |
New Member
There is a product available in most auto stores called Sea-Foam. It says you can add it to your crankcase oil and directly into the carb, but I don't feel comfortable doing that. I used it last spring with an old 80's Ford Straight 6 pickup that we were selling at an estate auction. The truck had been sitting for years (not sure how long) and would not start. So we put a can of this in the tank and topped it off with gas. Turned it over a little bit to get some new fuel in the lines. Waited 2 days and went out and the truck started right up! It worked really well as an anti-varnishing agent.
Here is the product sheet from their website if anyone is interested: http://www.seafoamsales.com/motorTuneUpTechGas.htm
Kris I'm about hot cars and fast women. Or was it hot women and fast cars? |
04-12-2006, 06:11 PM | #15 |
Hey here is another easy way to drain the tank, if you have a vacuum guage tester or brake vacuum guage for bleedingt brakes then seal the tank with the cap, hook the pump up to the fuel line pump until the pressure rises then you will see the fuel just come out of the hose, drain into a gas can or jug, while it is draining open up the gas tank, this will make it drain super fast.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
