Old 04-10-2006, 08:54 PM   #1
weasle
weasle's Avatar
Good body shop in Raleigh, NC area.
Can anybody recommend a good body shop in the Raleigh, NC area? I just went to one today and I could have gotten a new truck for what he told me. Does 6 hours sound right to replace a cab corner on a '72?? I need to get both cab corners, both rockers, and both rear wheel housings replaced.
weasle is offline   Reply With Quote
Old 04-10-2006, 11:53 PM   #2
Alex Hayley
Re: Good body shop in Raleigh, NC area.
I have looked around the area and have found no place that is interested in doing restoration work. They are only interested in collision work. You might want to check in some of the smaller towns between the triangle and Charlotte.
Alex Hayley is offline   Reply With Quote
Old 04-11-2006, 07:05 AM   #3
weasle
weasle's Avatar
Yeah, that's what I've been running into also. Thanks for the reply.
Old 04-11-2006, 07:24 AM   #4
byrd
Union Electrician
byrd's Avatar
No body shop wants to do this type of work, they all want those 2 day insurance work. Some will take it in a use it as busy work, but watch out they may never finish it, and if they do it may take them a couple of years. Good luck and hopefully you will find someone who is willing to do it.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 04-11-2006, 07:31 AM   #5
Liz
Catchy title goes here..
Liz's Avatar
if you cant find anyone out there.. we have a really good guy here. PM me and I'll get you the info if you want it.. he is a good ol boy, from GA who works in a shop at his house. Is military so goes back n forth with training and all.. but so far good work.. VERY good prices and well just all around cool guy.
Liz is offline   Reply With Quote
Old 04-11-2006, 12:04 PM   #6
1969 C/K CST
A.K.A- Crummy
1969 C/K CST's Avatar
http://www.classicjunkyard.com/restorers/NC.html
2003 Silverado Z71 Are fishermen all liars?
1969 C/K CST is offline   Reply With Quote
Old 04-11-2006, 02:08 PM   #7
phlegm
Still Green but learning
phlegm's Avatar
Bell ford bodyshop in Mebane NC gave me a decent quote on my truck (3k for paint with the Bed off also fixing my rocker and flatening dings). You may want to check with them. Now back then he was an independant working leasing the shop, I think now he works for the dealer since they just changed ownership... It still may be worth a call.
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 04-11-2006, 05:32 PM   #8
71chevytruckguy
71chevytruckguy's Avatar
if your willin to come up to around winston-salem, nc there are two really good places.
Smitty's Collision and Restoration Service
(336) 996-2251
745 Indeneer Dr
Kernserville, NC 27284
or
CARS
Classis Automotive Restoration Services
(336) 595-3900
Fax: (336) 595-4900
www.classicautomotiverestoration.com
8235 Nautical Point
Belews Creek, NC 27009
hope that helps. chris.
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 04-11-2006, 06:19 PM   #9
Rokcrln
Rokcrln's Avatar
Good luck it seems these days all shops want is Ins. work. This is one reason I started doing resto work in my home shop part time and I am turning guys away right now due to not enough time for everyone. As far as the 6hrs goes I went and checked my log book and the last one I did was 4hrs start to finish but that was on a gutted out cab (no interior time for pulling or covering) and I had to section the corner to get it to fit just right. If it had not needed to be sectioned it would have been about 3 to 3.5hrs.
Kevin
LFD Inc
Rokcrln is offline   Reply With Quote
Old 04-11-2006, 09:24 PM   #10
woodchip
I had the same problem no one cared about doing it, and auto rebuilding shops around here (Reedy Creek NC.) are like flies on cow dung. So I just bit the bullet and replaced them my self. I replaced left front floor panel,left kick panel, lower end of left front pillor, both front cab suports,left and right rockers,both cab corners, and patch 3or4 rusted out holes. The welding was not so pretty at first but got better as I went along ,turn out pretty good,pictures later. EbFabman's 3 DVD Cab repair video set help lot Reconmend highly. http://www.ebfabman.com/
98 Chevy Z71 1500 extended cab
99 Dodge carvan es
68 Chevy C10 LWB 50TH 396 eng 400 Trans
62 Wheel Horse tractor in good shape
woodchip is offline   Reply With Quote
Old 04-11-2006, 09:36 PM   #11
weasle
weasle's Avatar
I've actually been thinking about trying it myself. I don't have any body work skills but I'm willing to try. I have been to http://www.ebfabman.com/ before but its not up now. Thanks to all for the help.
Old 04-11-2006, 11:02 PM   #12
byrd
Union Electrician
byrd's Avatar
Efab is a member here and all who have bought his videos have given it high markes..
Zip:40272
