04-11-2006, 08:13 PM | #1 |
Do I have to C-notch?
If I put a 6" drop in the rear of my 69 do I have to C-notch it, if so what is this difficult to do?
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
04-11-2006, 08:31 PM | #2 |
Re: Do I have to C-notch?
If you want any sort of travel in the back with out it slammin the frame then yes you do need a C-notch. I think it is recomended with any thing over 4" so with your 6" it is a safe bet that you would benifit from it. Here is a link to a C-notch I just did for a 2wd blazer. http://67-72chevytrucks.com/vboard/s...d.php?t=195566 if you have any questions just PM me as I do not get over to this page very often.
Kevin LFD Inc. |
04-11-2006, 08:49 PM | #3 |
WTB this ad
ECE claims that it's not necessary but mine hits under the right (wrong) conditions. There are tons of guys on here with 6" of drop who say they don't have problems.
04-11-2006, 08:54 PM | #4 | |
And if anyone has pics of an installed cnotch that would great.
04-11-2006, 09:10 PM | #5 |
I have 2.5-3" of travel = 6"ish drop. Never bottomed out hard enought to notice. The rubbers are trimmed to hit 1/2" before the frame but there are no marks showing it's hit.
Shock Angle is everything. Wrong angle horrible ride.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-11-2006, 09:38 PM | #6 |
WTB this ad
This is a pic I had on file. There is about 2.5" between the frame and the axle tube. Going down the road, normal bumps, rough bridges no problem. Drop off a tall speed bump to fast with a couple hundred pounds in the back........BAM! Super potholes...........POW! Yea I guess I could ease around with it like it was made of eggshells...........but I wont! A notch is probably in my future.
6" of drop in the rear. |
04-11-2006, 09:44 PM | #7 |
See Ten I was wondering what size drop you put on ur pickup? And where did you get and if you were satisfied with it. I was planning on getting the one from early classic, they wanted somewhere around $800 for a 4/6 drop everything included. Oh year and what size tires and rims do you have, trying to get an idea on the stance. Thanks
04-11-2006, 09:53 PM | #8 |
WTB this ad
The drop is all early classic. I went 3.5" in the front and 6" in the rear. The wheels are 17x9.5 with 4.75 BS and a 275/60 in back. The front is 17x8 with 4" BS and a 255/50. I also used their extreme drop crossmember and converted to a one piece driveshaft. She rides and handles great but needs a little more room for the axle to swing up in the rear. I personaly would recomend 5" in the rear if you don't want to notch it. I really didn't want to notch mine but I like how she sits.
04-11-2006, 09:59 PM | #9 |
What do you recommend about the extreme drop crossmember and the one piece driveshaft, can i get by without using them? BTW I love you pickup you did an awsome job on it.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban Last edited by 67chevy2wd; 04-11-2006 at 10:03 PM. |
04-11-2006, 10:09 PM | #10 | |
WTB this ad
04-11-2006, 10:20 PM | #11 |
So when I drop the front is that going to bother my factory swaybar?
04-11-2006, 10:24 PM | #12 | |
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
