Old 07-27-2002, 09:33 PM   #1
GABE310
GABE310's Avatar
Unhappy Need HELP!!! NO SPARK
I'm having trouble starting my new engine. I have everything connected right ,but when I turn the key it just turns over and does not fire up. So I checked to see if I had spark ,but their is no spark. I disconnected the coil wire and their is no spark coming out of the coil, But their is power to the coil. Can someone please tell me how I can test the coil. Or can some one help me trouble shoot it. Thanks
68 CHEVY SWB
95 HARLEY DAVIDSON NOSTALGIA
68 CAMARO CONV
65 CHEVELLE CONV
39 CHEVY CABOVER
GABE310 is offline   Reply With Quote
Old 07-27-2002, 09:38 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
Your power comes into the coil, from the resistor wire, at the + side. The wire from the distributor goes to the - side of the coil. Are you positive that's the way it's hooked up? You might try, that, and if nothing else, find a friend with an extra coil laying around, and swap them...see what happens....
Good Luck....Sorry I couldn't be of more help.
TJ
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 07-27-2002, 09:43 PM   #3
bigvinnie
bigvinnie's Avatar
what he said.... swap in a known good coil and tell us what you get..
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 07-27-2002, 10:18 PM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Cool THE SPARK
HOOK YOUR WIRES LIKE '68 SAY'S. THE YELLOW WIRE IS YOUR RESISTOR WIRE, POS SIDE OF YOUR COIL , POINTS WIRE TO THE - SIDE. CHECK GROUND ON MOTOR . VOLT METER, GOTTA HAVE ONE IN THIS BUSINESS. + LEAD TO POS SIDE OF COIL, GROUND - LEAD TO BLOCK. TURN OVER MOTOR, YOU SHOULD GET AT LEAST12 VDC . WHEN IT STARTS , IT SHOULD DROP BACK TO UNDER 9 VDC. IF YOU HAVE THIS VOLTAGE (12 VDC) AND IT ISNT FIRING CHECK COIL LIKE IT WAS POSTED BEFORE. ALSO, SMALL ENGINE SHOPS SELL A IN LINE FLASHER LIGHT, IT LIGHTS WHEN IGNITION SPARKES. COMES IN HANDY WITH THESE KIND OF PROBLEMS. GOOD LUCK
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 07-27-2002, 10:56 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Hey D, the yellow is not the resistor, the white one is. The yellow, which should also be hooked to the positive goes down to the starter and is only hot when you are cranking it. That is why it goes up to 12 volts when cranking over.
Old 07-27-2002, 11:21 PM   #6
GABE310
GABE310's Avatar
I swapped it with a good coil and it still just turns over ,but does not fire up. I put in a new MSD ready to run Distributor and MDS coil. Would the battery have something to do with the problem? I took the one out of my 68 truck , but my 68 has a straight 6cyl and the motor I'm trying to start is a 350.
68 CHEVY SWB
68 CAMARO CONV
65 CHEVELLE CONV
39 CHEVY CABOVER
Old 07-27-2002, 11:41 PM   #7
GABE310
GABE310's Avatar
68 CHEVY SWB
68 CAMARO CONV
65 CHEVELLE CONV
39 CHEVY CABOVER
Old 07-27-2002, 11:41 PM   #8
Longhorn Man
If it is cranking, then the battery is good enough.
Where are you checking for spark, at a plug wire, or at the coil wire?
Old 07-27-2002, 11:44 PM   #9
GABE310
GABE310's Avatar
I checked it a the coil and at the #1 spark plug.
68 CHEVY SWB
68 CAMARO CONV
65 CHEVELLE CONV
39 CHEVY CABOVER
Old 07-27-2002, 11:46 PM   #10
Longhorn Man
Ok, If your not getting spark at the coil, it shoots holes in my idea.
Old 07-27-2002, 11:46 PM   #11
GABE310
GABE310's Avatar
If the timing is off by a bit would that cause it not to have a spark.
68 CHEVY SWB
68 CAMARO CONV
65 CHEVELLE CONV
39 CHEVY CABOVER
Old 07-28-2002, 12:13 AM   #12
68 Stepside
huh?
How much is a "bit"? Yes, that could cause it to not have spark, I've seen it happen.
TJ
RIP El Jay
Old 07-28-2002, 12:19 AM   #13
BOSS
Just here to help
BOSS's Avatar
Is it possible you have the distributer off 180 degrees? We had that problem on my brothers 350 but i am not sure if a 6 is the same
Support our site
Norwood Survivor
BOSS is offline   Reply With Quote
Old 07-28-2002, 12:24 AM   #14
GABE310
GABE310's Avatar
I put the piston to dead center and dropped in the new dist, but when I put it in the rotor was pointer forward straight down the block I lined up the #1 plug wire on the cap to the rotor. A buddy I just talked to told me the rotor had to point twords the #1 piston. Can some one please clarify that.
68 CHEVY SWB
68 CAMARO CONV
65 CHEVELLE CONV
39 CHEVY CABOVER
Old 07-28-2002, 12:34 AM   #15
BOSS
Just here to help
BOSS's Avatar
if it is possible take out number one plug and have someone bump start while you have your finger on the number one hole to make sure you feel it is on the compression stroke.
Support our site
Norwood Survivor
Old 07-28-2002, 01:43 AM   #16
Longhorn Man
It does not matter which way it is pointing.
Get it back to #1 top dead center. Confirm it is on the compression stroke by checking for air coming out of the spark plug hole like said. (plug removed) Then, after you feel air coming out, runt it untill the timing pointer is on 4 degrees BTDC.
Pull of your dist. cap, and where ever that rotor is pointing, place the #1 wire over it. (turn distibuter a little laft or right to get the wire right over the rotor). Then follow the firing order and wire it all up.
You may still have to mess with it when you get it to fire, but this will get you in the ball park if not dead on. Use a timing light to get it set after all is said and done.
Old 07-28-2002, 02:26 AM   #17
TERRYP
GYRO GEARLOOSE
TERRYP's Avatar
If your timing is off, you will get exactly the same spark at the plugs anyway, just not at the right time. If you have no spark, the most likely cause is that the points are not opening. you can make a coil spark simply by hooking juic to the + side, and grounding the - side, and you will generate spark when you un-ground the wire. (a lot of dwell here, though!) That is the easiest way to check the coil. If the coil is good, make sure the points are opening, then be sure you have a path to ground for the points.
Nevada City, CA
Everett, Washington
57 3/4 rat, 235, 3spd
66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring
68 C10 LWB 350 4spd, 4.56 rear dump runner
82 Camaro, 305, THM-200-R4
84 Monte Carlo 305 TH350, land tuna
85 Tercel SW, snow runner
DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB
TERRYP is offline   Reply With Quote
