04-12-2006, 08:32 AM | #1 |
Removing upper Panhard bar bolt
I could not get the upper bolt to budge last night. I got the nut off, but the bolt will not back out at all. Does anyone have any suggestions or tricks?
www.diverserides.com WTB 67-68 SWB, 350, Auto, Coil frame, Discs up front - PM me with details |
04-12-2006, 08:35 AM | #2 |
Re: Removing upper Panhard bar bolt
jack up the frame let the rear hang so theres less load on the bolt
04-12-2006, 08:58 AM | #3 |
LOTS OF PENETRAITING OIL (LIKE P B BLASTER) & A LONG BREAKER BAR. I'VE FOUND A LITTLE WELL PLACED HEAT HELPS TO REMOVE A NUT THAT HAS BEEN IN PLACE FOR OVER 35 YEARS. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
04-12-2006, 09:57 AM | #4 |
I have the nut off and the bolt spins but it looks like it is stuck inside where it goes through the bar end.
04-12-2006, 10:29 AM | #5 |
try a C-clamp and a socket to press it out
04-12-2006, 10:50 AM | #6 |
I used an acetelene torch to heat the head and the thread end red hot, then whacked it good with a hammer and a punch, came right out then. I had tried everthing else and it didn't work. I also had the box off at that time so if you do that with the box on be careful.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-12-2006, 02:02 PM | #7 |
A BFH worked for me!
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD |
04-12-2006, 02:11 PM | #8 | |
Next project: 1970 K10
Try putting the nut back on so you don't damage the threads and whack it good, or just beat the h@LL out of it and get a new nut & bolt.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
04-12-2006, 06:57 PM | #9 |
saving one more
I had to hacksaw the bolt out, it was frozen in the inside sleeve of the bushing. I cut both sides of the bolt inside the bracket, was very tedious to do, not much room for a hacksaw, BFH wold not even budge mine, just smashed the end of the bolt
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab Last edited by rauto13; 04-12-2006 at 06:57 PM. |
04-12-2006, 11:06 PM | #10 | |
Cantankerous Geezer
Fred There is no such thing as too much cam...just not enough engine. |
04-13-2006, 10:46 PM | #11 |
My frame was on jackstands when I tried to get the bolt out and when I used a BFH it just moved the whole frame.
What finally worked for me was just spinning an impact for about 30 seconds. The bolt spung freely before but didn't want to be pushed out. If I cut the head off the shaft still would have been stuck |
04-13-2006, 10:50 PM | #12 |
Cutoff wheel and sawsall got mine off. BFH wouldn't work for mine or heat or pbblaster.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
