Old 04-19-2006, 06:49 PM   #1
dirtybird1
dirtybird1's Avatar
1984 4 speed manual
What transmission is this thing? Its a 84 Silverado 4x4 1/2ton. 4 speed manual, and where can I find parts for it??? Thanks guys
Matt
dirtybird1 is offline   Reply With Quote
Old 04-19-2006, 07:50 PM   #2
Russell
Professional Grade
Russell's Avatar
Re: 1984 4 speed manual
Does it have a low first gear?
If so, its an SM465, and there are parts for it all over the net. If its got overdrive, or doesn't have a regular low gear, then it is something else.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-19-2006, 08:44 PM   #3
dirtybird1
dirtybird1's Avatar
Damn, yea it doesnt have a low 1st gear. Anyone else?
Old 04-20-2006, 09:16 AM   #4
Russell
Professional Grade
Russell's Avatar
Can you possibly get pictures of it? It might be a car transmission that was swapped in
Old 04-21-2006, 02:29 PM   #5
Kopper
You may have the 4 speed overdrive trans that was used in the early to mid 80's. The GM production code is MY6, and the transmission is a New Process A833. A dealer can check your VIN number and tell you if that's what you have.
You should be able to get parts from the dealer or through a transmission shop. I've purchased seal and gasket sets through trans shops at reasonable prices. The shifters used on this trans were made by Hurst.
Kopper is offline   Reply With Quote
