Old 04-20-2006, 04:49 PM   #1
NateObee
NateObee's Avatar
Loose hard top bolts. Help!
i'm sure i'm not the only one with this problem. you can tell an engineer designed the attachment system. if you've ever tried to put an 1st gen top on the ground, watch the bolt's! get some bricks! luckly i have a small pick-up that don't run to hold my blazer top for me when i don't need it. but...
many of the bolts are loose, still in the top but they tilt and some spin. makes it a trick getting them to hit the holes on the way back on. does anyone have an sugestions on how to repair this problem. i assume i can just dump a bunch of poly-resin down the hole and clamp them in place, right? anyone done that? or know any thing that works better?
Nate
NateObee is offline   Reply With Quote
Old 04-20-2006, 04:56 PM   #2
Medicanman71
Medicanman71's Avatar
Re: Loose hard top bolts. Help!
Dunno, Nice avatar!
Medicanman71 is offline   Reply With Quote
Old 04-21-2006, 12:28 PM   #3
NateObee
NateObee's Avatar
Originally Posted by Medicanman71
Dunno, Nice avatar!
thanks. it's a big pile of snow, if you can believe it. biggest one i've seen in a parking lot in quite a while. i prolly could have gotten on top if i wasn't afraid of high centering. though it would have melted away eventually and left my truck on pavement. it's any easy way out, but takes a while.
Nate
Old 04-20-2006, 05:13 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I'm guessing you have a double wall top? Sounds like the inserts have broken loose You may try some JB weld or some fiberglass resin to hold them in place. I'm not exactly sure how the doublewall tops bolt up since I've only had single walls.
Why would you leave the bolts in the top when it wasn't on the truck?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-20-2006, 08:30 PM   #5
71jimmy
71jimmy's Avatar
IF you have a double wall and your talking about the bolts/nuts along the bed rail then it is the nut part that is loose inside your fiberglass. These are fastened with rivets. They are actually metal stips, 3" by 3/4" by 3/16, with a whole drilled in the center and tapped for the bolt. The only way to get them out is to drill the head of the rivets out. Drill a one inch whole, with a whole saw, just up the inside of the top. Then fish them out. I had to replace multiple ones so I drilled the hole between two of the nuts, so I could get to them with only one hole in the top. I had broken bolts in them that were rusted so badly they wouldn't break loose. I just bought some steal and made my own.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 04-23-2006, 11:15 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Seems like that is oneof the draw backs of a double wall top I have to do mine this summer..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
