Old 04-21-2006, 08:55 AM   #1
oj70chevy
250 V-6 Club
oj70chevy's Avatar
what oil and Tempriture sending units
I have a 70 Chevy c/10 that I am converting from dummy lights to gauges. I need some help with what oil and Tempriture sending units would I have to get in order to fit the 250 straight 6cyl. I have only seen them for small and big blocks . Do they make something I could use to make this happen on my 250 6cyl? Any help would be highly appreciated.
Thanks Ralph
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 04-21-2006, 09:03 AM   #2
Green Machine
Green Machine's Avatar
Re: what oil and Tempriture sending units
The oil pressure is a mechanical gauge, just run an oil line to the engine, steel is best, with a coil or two in it for vibration like factory, the temp sender should be the same as any small block with gauges.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-21-2006, 10:02 AM   #3
oj70chevy
250 V-6 Club
oj70chevy's Avatar
thanks for the rply. any idea where I could get the Steel line for the oil guage? I have only seen copper at autozone. also the temp sender would one fit from a 350 8cyl?
Old 04-21-2006, 11:41 AM   #4
Green Machine
Hunt around, someplace will have steel line, but copper is better than plastic, copper can crack from vibration over time. Sender for a 350 should work. Check parts board, someone may have all the parts you need.
