04-21-2006, 10:45 PM | #1 |
Aluminum cleaner??
I need an aluminum liquid cleaner to clean up the 6.0 that I bought any suggestions?
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844 |
04-21-2006, 10:57 PM | #2 |
Re: Aluminum cleaner??
oven cleaner
04-21-2006, 11:03 PM | #3 |
I bought some oven cleaner in the dollar store so that will take care of it thanks.
04-22-2006, 12:59 AM | #4 |
DO NOT use oven cleaner on aluminum, you'll be very very sorry, read the can label !!!
What are you trying to get off, light grease ??? Mix up some dish soap or Simple Green 50/50 with water and spray it on, let it soak for a whaile and hit with a power washer or car wash.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
04-22-2006, 02:08 AM | #5 |
My friend told me touse Aluma Brite has any one used it before?
04-22-2006, 06:04 AM | #6 |
What are you cleaning?
Lots of cleaners and chemicals will etch aluminum. |
04-22-2006, 06:48 AM | #7 |
NO OVEN CLEANER!!!! I always use "Simple Green" or "Castrol Super Clean" on aluminum. Oven cleaner can turn the aluminum black and can etch it bad....
1997 GMC Sierra Ext 1965 Mustang |
04-22-2006, 11:48 AM | #8 |
Castrol Super Clean can also etch aluminum, I found out the hard way.
How about regular engine cleaner? I have had good luck with Foamy Engine Brite, I think it is safe for aluminum.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
04-22-2006, 12:11 PM | #9 |
67-72 Addict!
I also like the Foamy engine brite for engines!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-22-2006, 12:21 PM | #10 |
if you live near a truck stop they will have aluminum acid takes every thing off
04-22-2006, 12:28 PM | #11 |
Premium Level Member
Mequires aluminum cleaner works great.
69 K5 CST stock- 350, 4speed 77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's, |
04-22-2006, 02:51 PM | #12 |
i use oven cleaner on all my stuff.... never had any problem with it.......need pics of how it cleans up
http://www.ls1tech.com/forums/showth...7&page=1&pp=20 never had any problems with it. been doing this for over 6 yrs now too. |
04-22-2006, 03:42 PM | #13 |
water will work just fine if it's run thru a pressure washer
04-22-2006, 05:16 PM | #14 |
Oven cleaner will work if you plan on painting it like 68 short step did.
But it will turn it colors you dont want if you want to leave it bare aluminum! So Dont use OVEN CLEANER!
For every person with a spark of genius, There are a hundred with ignition trouble. 70 Short/Step |
04-22-2006, 05:28 PM | #15 |
04-22-2006, 07:41 PM | #16 |
Use Aluma Brite at work on diamond plate aluminum plates on exterior of truck. Removed all stains. looks good. just spray it on and let it do the work. Think we got it at B-Line.
04-22-2006, 10:26 PM | #17 |
most boat shops will have products to safely clean and pollish aluminum as well
common sense isn't so common anymore |
