Old 04-24-2006, 09:53 PM   #1
Daves72'GMC
Smile Gas tank ,fuel line vent tube?
I Have a 1972 gmc 3/4 that I'm restoring and where the 2 fuel lines come from the fuel tank and go through the cab floor, one line is the big one which I know where it goes ,but where does the smaller one go(where does it hook up too?)? I believe it's a vent line. Thank you everyone.Dvae
Daves72'GMC is offline   Reply With Quote
Old 04-25-2006, 05:10 AM   #2
JimKshortstep4x4
Re: Gas tank ,fuel line vent tube?
The smaller line is a return line and connects to the fuel pump. (Your fuel pump on the 72 should have an extra outlet on it which is the same size as the return line).
Jim
Old 04-25-2006, 10:42 PM   #3
Daves72'GMC
Smile Re: Gas tank ,fuel line vent tube?
I put an edlbrock fuel pump on and it doesn't have the vent line on the fuel pump, so what do I do with the vent line coming from the fuel tank? Thank you
Old 04-25-2006, 10:57 PM   #4
clay68c10
clay68c10's Avatar
I'd plug it. No need for it with the aftermarket pump.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 04-25-2006, 11:33 PM   #5
Green Machine
Green Machine's Avatar
If you plug it be sure to run a vented gas cap from an earlier year. If you don't you will either stave engine for fuel or colapse the tank.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-26-2006, 05:50 AM   #6
dwaite72lnghrn
Yep you will definitly have to plug this line or when you fill the tank it will syphon fuel out onto the ground.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 04-27-2006, 10:40 AM   #7
Daves72'GMC
The gentleman that is restoring my truck ,said he would just run a hose next to the frame rail with some kind of valve at the end,so it would vent. Does this sound fine .Would it just be better or easier to put the stock type fuel pump back on ,so I don't have to mess with the vented cap. I'd like to keep the origional cap on. Thanks guys for all of your help.Dave
Old 04-27-2006, 11:17 AM   #8
cdowns
cdowns's Avatar
the original vent goes up into the rear passenger door pillar then down thru th fllor up to the charcoal canister i've always eliminated the canister and had the rubber hose along the frame rail there is no chance of it siphoning out becauce of the height of the vent loop i've never seen a gas pump with a return line on the 3 71-72AC trucks i've had
Old 04-27-2006, 05:49 PM   #9
dwaite72lnghrn
I don't think a check valve on the end of the line that vents air both directions will stop the fuel from dumping. My tank lines follow the same path from the tank to the fuel pump. There is no high arch in the hose. When I changed over to electric pump I left the return line there with a loose hose to the other line( rerouted new lines) after the tank was filled and it sat the fuel would dump from the line, I then clamped them tight so it wouldn't leak. If you run an extra hose up high enough like the other trucks then it would be ok as the fuel wouldn't go up that high blocking your vent.
2009 HHR aqua blue
Dave & Jeanne
