04-25-2006, 10:09 AM | #1 |
help
okay i'm back for one but with a new problem i went out to replace my turn signal switch i can figure out how to get the new wires run though the cloumn and the other in the bearing under thew switch needs to be replaced how do i remove this and what is it call? i need to try and find a parts store around here and get one because4 the truck is my means of travel
04-25-2006, 02:05 PM | #2 |
Re: help
nm i found the part number and got the part at the local classic muslce restoration shop and got everything together and working great
04-25-2006, 05:05 PM | #3 |
Re: help
good job. classic muclse is great for high qualtiy parts and good service. got a bunch of stuff for them. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
