04-26-2006, 11:01 AM | #1 |
pulley alignment?
I see light at the end of the tunnel!! Finally, I have the 350 / 700r4 package installed, and picking up my driveline today. I'm down to installing the accessories, fuel line, radiator, TCC adjustment, shift linkage, etc. A previous owner decided to pull the A/C compressor and installed a different pulley setup. It worked ok before I removed the engine, but I discovered that the harmonic damper was not fully seated..perhaps to help in alignment. Anyway, please see attached pics - the power steering pulley alignment is off. Is there an offset pulley available? I know the eng is a circa 1978.
Any ideas - I do want to re-install a/c at some point, but now at this time. I just want to get her running.
___________ Greubin '71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI |
04-26-2006, 11:06 AM | #2 |
saving one more
Re: pulley alignment?
dumb question, but just maybe...
Is the pulley on the power steering pump fully seated?
72 Chevy longbed - now for parts 69 Chevy short fleet - needing some love 70 RS Camaro - needing more love driver - 96 GMC X-cab |
04-26-2006, 11:28 AM | #3 |
more dumb questions, was that pump on a GM before? are you mixing short and long water pump accessory mounts?
04-26-2006, 11:32 AM | #4 | |
More detailed pics below...
___________ Greubin '71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI Last edited by Greubin; 04-26-2006 at 11:40 AM. |
04-26-2006, 11:39 AM | #5 |
saving one more
I think you may be right about mixing long & short water pump pulleys. The power steering pump looks like the correct one, but it looks like a long water pump in the top photo.
I have the same alternator mount on my truck and a long water pump. The power steering pump & brackets I have are from a later setup also, I would guess like a 75 Chevy ps pump on mine. That may be what you need, although I don't like mine and will be changing it. Hose routing is really bad on my setup and tears up hoses pretty fast. I am going to a serp belt setup off a later model vehicle so that I can quite worrying about this, I have hunted & gathered numerous brackets & pulleys trying to move the alt back to the left side of the engine, so that I can hook up the factory air. By the way, the PO on my truck had shimmed the alt out with washers trying to get everything to align correctly.
04-26-2006, 11:43 AM | #6 |
Thanks for the quick replies...I love this board - best "tech support" out there
The water pump, balancer pulley, and the inside groove on the alt pulley line up.
___________ Greubin '71 C20 custom - GM Crate 350CI/290HP, BTO 700R4 level II, Qjet, and HEI Last edited by Greubin; 04-26-2006 at 11:46 AM. |
04-26-2006, 11:51 AM | #7 |
with aftermarket AC usually -- most likely inside pulley is power steering, 2nd pulley is alternator on drivers side, third toward radiator is AC on passenger side.
04-26-2006, 09:37 PM | #8 |
I cant really tell by the pics but is the ps pulley set in just a little? Mine was once I switched to a long pump & used misc pulleys. All I did was remove the rear bracket bolt(the one on the motor mount) & put a washer or 2 behind the 2 bolts in the block. It worked just fine.
04-26-2006, 10:37 PM | #9 |
I was wondering about this I have the exact same problem. I put the setup back on the motor that I got with it but for some reason my power steering pump pulley sits about 1/2 inch forward of were I need it to line up with the water pump pulley.
07-30-2011, 09:56 PM | #10 | |
Posted via Mobile Device |
08-02-2011, 01:57 AM | #11 |
check out this site. He has more pulley and measurement info on this subject than you can shake a stick at. www.alangrovecomponents.com
