Old 04-27-2006, 02:06 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
VooDoo Cams by Lunati
VooDoo Cams by Lunati. Anybody here run them? I'm thinking of going with one for my BB and get rid if the Comp Junk
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is online now   Reply With Quote
Old 04-27-2006, 04:19 PM   #2
epthree04
epthree04's Avatar
Re: VooDoo Cams by Lunati
yeah i was just looking at them today. seem like pretty nice cams but i dont have any personal experience with them.
epthree04 is offline   Reply With Quote
Old 04-27-2006, 04:34 PM   #3
Ole Blue 68
Ole Blue 68's Avatar
I put one in my rebuilt 350. I like it so far.
Ole Blue 68 is offline   Reply With Quote
Old 04-27-2006, 06:51 PM   #4
82c10
needin' money
they are ok, next time i think i will get a comp extreme energy
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 04-27-2006, 08:13 PM   #5
Primed67
Primed67's Avatar
I haven't ran one but I've got comp extreme energy and love it. it's been in the truck for at least 6 years now with out any issues. It still hits hard as hell.
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 04-27-2006, 09:45 PM   #6
dinnut
dinnut's Avatar
i have one i just have not installed yet... hopefully it works out
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 04-27-2006, 10:33 PM   #7
franks72
Junior Member
franks72's Avatar
I installed a comp 270 hyd roller cam in my BB cant wait to try it out....
franks72 is offline   Reply With Quote
Old 04-28-2006, 01:37 AM   #8
Frizzle Fry
Frizzle Fry's Avatar
Everyone I've talked to seems to think they are superior to the comps. I'm going with a voodoo for my 396.
Frizzle Fry is offline   Reply With Quote
Old 04-28-2006, 05:33 AM   #9
mike nutt
69fatmotor
mike nutt's Avatar
i,ve got one in my 396 , but haven't fired the motor yet.
mike nutt is offline   Reply With Quote
Old 04-28-2006, 10:29 AM   #10
1970 CST Short Wide
Senior Moment
I need to vent some here
The new Comp 280 cam and the new Comp 270 cam I installed in my 454 both sounded like SH!T after warming up. No matter how you adjusted from 1/4 turn to 2 turns and yes the lifters are turning, the oil pressure and feed are excellent and no, there not flat. I even had the lifter bores redone because I couldn’t find anything else to blame it on. After talking to a lot of different people in the machine shop business (I was in the bis for 16 years myself) the first question they would ask is what brand cam do you have? When I said Comp they said “there’s you problem”. I have never heard a hydraulic cam sound so loud, like it wanted to jump out of the motor. Comp Reps told me this is now normal. I say BS. After the customer service run around and telling me this is normal I will never use a Comp product again as long as I live.
I’m going to change to the VooDoo soon. I have to get back motivated. I’ve parked the truck since all this has been going on for the last 6 months or so.
I’ll let you all know how it turns out.
Thanks for letting me get this off my chest, I feel a bit better now
Pittsburg Ca
94565
Old 04-28-2006, 10:51 AM   #11
retro69
Mike Nutt, man I love the valve covers, where did u get them from and are they painted or powder coated. I have a 396 out of an 1969 chevelle in my SS. I used the 268EX it's a stout cam until about 3500 to 4000rpm, I later blew the top of a piston to much compression. I swapped to an Comp 292S solid lift camshaft it was too much for the street, so I swapped in a 274XE it was the best proforming cam as far as street/strip, not bad on gas as you might think. But I ran into a problem the #7 exhaust lobe rounded of the lifter was concaved, I had valvetrain noise that would not go away no matter how many times I adjusted the valves. So very pissed I took the cam to Comp here in Memphis. They gave me full credit for the cam and swapped to a 282S, that I have not gotten a chance to break in the cam started walking hitting my timing cover even tho comp said the problem was with endplay at the distributor and camshaft gear. I spent 100 bucks on new distributor and it still was walking. So I will be swapping my timing chain for a single roller and a cam button. This is the last comp cam for me I will try a voodoo next. Lots of people at the tracks in at Memphis Motorsports are using them. JMO
1969 C10 Long Wheel Base
1985 Monte Carlo SS(Snake Charmer)
retro69 is offline   Reply With Quote
Old 04-29-2006, 08:31 AM   #12
mike nutt
69fatmotor
mike nutt's Avatar
retro69, the valvecovers are painted, they are made a place called EDDIE MARINE, it's an aftermarket company for the high performance boat industry, the valvecovers are designed to clear roller rockers and also clear the coldwater exaust manifolds, these were polished aluminum but i glassbeaded them and did the paint work on them after they were etch primed. i got the used from a local boat shop that was going out of buisness for only ten dollars. the voodoo cam i'm running is the 276. thanks.
Old 04-28-2006, 11:01 AM   #13
hgs_notes
GEARHEAD
hgs_notes's Avatar
I just looked at the Voodoo 268 for my 283. I'm trying to find a replacement for the Crane Blazer can I used to have when it was a manual shift tranny. Switched to another milder crane cam and rhodes lifters when I put the automatic in. I didn't have a stall converter so I needed a better idle. That was a mistake though. I lost so much power, its pitiful.
So now the Crane blazer has been discontinued. They don'y have the same grind anymore, but a couple that are close. The Lunati 268 was close to the same duration, but has more lift by about 10-15 thousands. The crane Z-274-2 and H-278-2 are the closest match and will probably be what I get.
I'm running 1.6:1 roller rockers with it, think I'll stick with the rhodes lifters and get a stall converter. Then recurve the HEI or replace it. If that doesn't wake it back up, then I'm getting a turbo and quit screwing around.
HG
hgs_notes is offline   Reply With Quote
Old 05-01-2006, 08:35 AM   #14
4x4Poet
Mr. Nutt, thanks for the engine porn.
Best wishes with that Edel Performer.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-01-2006, 12:39 PM   #15
68Stepbed
68Stepbed's Avatar
I've heard lots of complaints about Comp Cams in big blocks lately. I've also noticed not too many people like them in certain Ford engines either. On the other hand, I've never heard the first complaint about them in small block Chevy engines and Small Ford engines(289,302). I think Comp does all their R&D for the most commonly built engines(sbc). If I ever go with a BB, I think I'll go with a Howard's cam or a VooDoo cam.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
