05-07-2006, 07:11 PM | #1 |
Cowl Scoop Install
After a few weekends of fabricating, the metal cowl scoop is attached. I used a two part epoxy adhesive designed for metal with large head sheet metal screws to hold it down. I will grind the heads off next weekend and begin the body work to blend the scoop edges into the hood. Welded the front tip to the hood. After a lot of head scratching we chose to flatten the front point of the hood rather than try to notch the scoop to fit over the center rib of the hood. I will post a few pictures of that if any of you are interested. If I had to pay to have this done it would have been cheaper to buy a cowl hood but with a little help it cost about 1/4 of a new hood. Enjoy the pictures.
05-07-2006, 07:15 PM | #2 |
Re: Cowl Scoop Install
Finished project. Onto body work next weekend.
05-07-2006, 08:28 PM | #3 |
nice, cant wait to see it done.
05-07-2006, 08:44 PM | #4 |
so why not weld the whole scoop onto the hood ? if ya do a spot at a time and cool it off there would be minimal warpage and it would be forever. ?
05-07-2006, 11:15 PM | #5 |
Saving 1 truck at a time!
Looks good Larry. Can't wait to see it.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
05-08-2006, 12:05 AM | #6 |
I had a lengthy discussion with the vendor. They recommend the epoxy and feel that it is every bit as strong as a weld. They use this stuff on aircraft wings. Thanks for the input.
