Old 05-08-2006, 04:37 PM   #1
el curioso
el curioso's Avatar
700-r4
Changed tranny filter and fluid now the tranny won't shift into 3rd I think this trany is prety much screwed but I dont want give up just yet. Any input sugestions or advive is welcomed . thank you
It's a 700r4 in a 1969 chevy c-10 with a 350 2 barrel carb.
el curioso is offline   Reply With Quote
Old 05-08-2006, 05:40 PM   #2
motocrosschump
Re: 700-r4
TV cable adjusted right?
2006 Titan SE Crew Cab Daily Driver
2005 Mazda Tribute (Wifes car)
1969 C10 SWB 350/3 Fleet "Max"
1969 Chevelle 2 door 350/3
motocrosschump is offline   Reply With Quote
Old 05-08-2006, 05:52 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: 700-r4
Agreed, Tv cable out of adjustment on these can trash em in a hurry
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-08-2006, 07:39 PM   #4
355
355's Avatar
Re: 700-r4
I changed fluid and I only had third gear. Pulled the panback off and found that I had pulled one of the solonoid wires loose due to pan/crossmember clearance. Had to look for it cuz it looked like it was still attached. Steve
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 05-09-2006, 01:38 AM   #5
el curioso
el curioso's Avatar
Re: 700-r4
I've adjusted the tv cable to how it states it in the manual so Im okay there i pull the pan off to see what gives and do a mod that i had been thinking of doing before getting as a daily driver what do you guys think.heres the mod
Old 05-09-2006, 09:12 AM   #6
woodridge
woodridge's Avatar
Re: 700-r4
In a 700R4 the wires control the converter lock up only. How did it work before you changed the fluid? If it had no problems before I would suspect a piece of dirt in the Throttle valve. This can cause late or no shifts. If this is the case, sometimes you can shake it loose by stomping the throttle several times while driving. Sometimes it work it loose sometimes not. If the unit is high mileage it may be time for some internal repairs.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 05-10-2006, 01:59 AM   #7
el curioso
el curioso's Avatar
Re: 700-r4
It shifted real smooth no probs. I never really paid attension to the shifting points.
