Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 05-09-2006, 03:22 PM   #1
pat
pat's Avatar
Anyone have a powered sub enclosure behind the seat?
I was looking at crutchfield and this looked like a good deal for the price. Does it matter that it will be behind the seat facing one side of the cab or the other, as opposed to sitting in the trunk of a car? I dont need a ton of bass, just a decent thump. I was wondering how this would work compared to a couple 8"s or 10"s in boxes facing the seat. It may be my best option considering how little room I have.
http://www.crutchfield.com/S-Ms6X0kQ...TB10AT&g=51000
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 05-09-2006, 05:00 PM   #2
shifty
Questionable
shifty's Avatar
Re: Anyone have a powered sub enclosure behind the seat?
i saw some pictures of someone around here that stuffed one of those pointing up and down in the rear cab corners. bass is non-directional, doesn't matter where you put it in the cab - except that the person close to it will probably feel more vibration than anyone else.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 05-10-2006, 11:13 AM   #3
Lemield
Lemield's Avatar
I put a Kenwood KSC-SW1 under the middle of my bench seat in my CST. I don't have a picture but it fit under there really nicely. It won't give you the heavy bass that a pair of 10 inch subs will but it sounds good to me.
Here is a link to a picture of it.
http://www.pricegrabber.com/rating_g...5816/id_type=M
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 05-10-2006, 12:18 PM   #4
Lippyp
English Chevy Owner
Lippyp's Avatar
I'm about to stick an RE8 8" sub, alpine mono amp and a big four channel amp for the fronts under the seat.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 05-10-2006, 12:54 PM   #5
76bonanza
76bonanza's Avatar
lemield how was the kenwood? been thinking about it myself for my system just want some bass not ear rattling but nice an tight.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 05-10-2006, 04:51 PM   #6
Lemield
Lemield's Avatar
I like it. It has a wired remote that you can adjust so that you get more bass. I think it helped my system a lot.
Larry
Old 05-10-2006, 05:17 PM   #7
76bonanza
76bonanza's Avatar
did you mount it under there or just slide it under?
1968 c10
lowered 3" 4"
Old 05-11-2006, 01:39 PM   #8
Lemield
Lemield's Avatar
I mounted it under the seat permanantly. I already had two 6x9 speakers under the seat. I also already had the seat adjuster cable disconnected due to the 6x9's so I don't know if it would need to be modified or disconnected if you installed one.
Larry
Old 05-11-2006, 06:06 PM   #9
76bonanza
76bonanza's Avatar
let me ask you a question lemield when you mount under the seat do you bolt it thru the floor? Or mount to a board then mount the board thru the floor?
1968 c10
lowered 3" 4"
Old 05-12-2006, 12:48 AM   #10
ChevyDude
here is how I did mine...Phoenix Gold 10" sub powered by PG 5 channel amp.....which puts 400 watts to the 10" sub! 6x9's behind the seats and components 6.5" and 1' tweets in the front. Just did this last week.
Alex
ChevyDude is offline   Reply With Quote
Old 05-12-2006, 08:52 AM   #11
Lemield
Lemield's Avatar
I just used a couple of self drilling sheet metal screws on each side through the brackets....right into the floor boards. I diod put down about three layers of Edead (dynamat type stuff) first.
Larry
