Can anyone help identify this front end? Someone told me they appear to be from a 73-87 C10. Right now it is on a 64C10 I bought from an estate. Any ideas? I want to put on drop spindles and springs but want to validate the donor first.....
Thanks!!!!! ![]() More pics at: http://www.whitehorsetechnologies.co...frontendid.htm Thanks in advance folks!
Glenn Cumming, Ga (68 C/10 Fleetside LWB 307 (64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty) (2001 Porsche Boxster S - 168 MPH of fun) (2005 Chevy Avalanche Z71 1500) |
Gone Fishing
Re: front end id help needed
It's a 73 and later
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
yeller
I agree ^^
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
So if I order drop spindle for a 73 will they fit or do I have to worry about wheither or not there is something different between the 73 and a 86???
Happy to be here
![]() Join Date: Mar 2000
You will need to check the thickness of the rotor. If it's 1" thick it standard, if it's 1.25" thick it's and HD. They use a different spindle...
#6 | |
I think I measured wrong...it looks now like its 1.5". The pads were an exact match for a 73C10 pads at Autozone. Also now that I measure it I wonder if its already got lower springs. They only have 10" of travel...is that right??? Pics here: http://cdrawdy.blogspot.com/
they are 1"......are they the same on all year models?
Hellion
Gotmud call up CCP or check em out on the net to see if they can help you out!!
#9 | |
yeller
73-87 C10 drop components interchange between all years, only difference is the rotor thickness, as Ken mentioned.
Thanks guys!!!!!!!! Ill send pics when she the rake is done...
I got a set of Cragar S/Ss to shoe her up with so a dropped front will look nice I hope.
Until Seventy Times Seven
Gotmud -
Are you going with 2 1/2" or 3" spindles? It's gonna look good if you can reach your goal. Your plan sounds good, but I didn't see where you were gonna drop the front. Sound like scope creep to me. ![]() BTW, when does 'annoying the neighbors' start. ![]() Good luck with your project. ![]()
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
I dont know boxrodz....is there that much diff between 2.5 and 3?
What da ya suggest? Are drop spindles from one vendor the same as another?
#14 | |
needin' money
SWB Stands for Short Wide Bed |
#15 | |
DMJ, Western Chasssis and Bell Tech all make decent drop spindles with pretty much the same specs. ![]()
#16 |
yeller
People have run into clearance issues when using 3" spindles and 15" wheels. I am not sure about your W&T setup, but it is something to consider if running 15" wheels.
If I could do it over again, I would have gone with a 2.5 spindle and 2" spring.
#17 | |
#18 | |
yeller
#19 | ||
