Old 05-13-2006, 12:59 AM   #1
4x4 70 Chevy guy
4x4 70 Chevy guy's Avatar
Power steering question
Ok, this thing obviously has a different front end under it but it has power steering(not sure if original) but its leaking where the shaft goes in. SO, I got a seal kit for it but i dont even know if this is the original gearbox that and I've never taken one apart. does anyone know if its difficult or have any advice? Also, does this look like its correct for a 70 3/4 4x4?
1970 3/4 ton 4x4 Lwb - 396ci. w/disc brakes up front
(work in progress)
4x4 70 Chevy guy is offline   Reply With Quote
Old 05-13-2006, 01:03 AM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: Power steering question
The truck has the original style pump so it probably is the original
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 05-13-2006, 09:32 AM   #3
Livrat
Member #1049
Livrat's Avatar
I can't say if your box is original or not.. but it is correct for the 69 - 80 4X4's,
Not able to help you on how easy or difficult it is to change the shaft seal.. I always leave steering boxes up to the professional rebuilders..
I did notice you have loosened and unscrewed the sector shaft preload bolt.. if you tighten that back down too much you will have problems turning smoothly and too loose you have lots of "play" in the steering.
Livrat is offline   Reply With Quote
Old 05-13-2006, 03:05 PM   #4
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
The bad thing about the seal kit is that the parts kit is for the larger diameter shafts, I dont think you can get the seal for the small input shaft anymore. Everyone I got was for the large one. There are 2 diameters for the input shaft, My advice is to buy a new one with a lifetime warranty and order a new coupler from a vendor.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 05-13-2006, 03:30 PM   #5
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
I've rebuilt two power steering boxes in my life. Both times they were difficult to take apart and difficult to properly reassemble. Since I didn't have a manual, I had to figure it all out for myself and I can tell you it isn't easy.
But if you are poor like me and have the time and the desire you can try it. When you succeed you can say you know how to do it. It will probably be a lot easier if you can find a manual. On the other hand, if you have the money or don't want a lesson in patience, I'd order a reman.
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
