Old 05-18-2006, 07:44 AM   #1
rocknrolloutlaw
71 disk swap
Question? What all do I have to change to put a d/b setup from a 71 half ton on to my 67 c20 (8lug) . I have both complete trucks. Do I just need the spindles, brakes ect? OR a arms? I could use a little help before i strip these trucks down.
rocknrolloutlaw is offline   Reply With Quote
Old 05-18-2006, 10:11 AM   #2
crazy longhorn
Fabricate till you "puke"
Re: 71 disk swap
You will need to swap the LOWER a arms, balljoints (upper & lower), & the tierods/sleeves, & centerlink. That will get your spindles to bolt on, then you just add the brake parts. The master will be different(drum to disc), & the hoses will be routed differently(save the brackets from the 71, & weld them to your crossmember). There may be some details I have forgotten , as it has been some time since I did my swap. best of luck, L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
