Old 05-20-2006, 01:29 PM   #1
shelby987
shelby987's Avatar
4" lift any driveshaft changes required?
If I put 4" springs in the front and blocks in the rear, do I need to make any changes to my front and rear drive shafts?
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 05-20-2006, 01:58 PM   #2
Mudder
Mudder's Avatar
Re: 4" lift any driveshaft changes required?
Shouldn't. If you notice any vibrations maybe drop the transfer an inch.
Mudder is offline   Reply With Quote
Old 05-20-2006, 02:42 PM   #3
I`ve never had to.
Old 05-22-2006, 05:37 PM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
Didn't on mine. 4" is within the reach of the stock drivelines. If you notice some vibrations it should be easy to fix. either by dropping the rear of the tcase or giving the rear axle a little more pinion angle(wedge under the block). Just go buy a magnetic angle finder at sears or other tool store (under $15) and measure the u-joint angles. The front and rear joints should be at equal and opposing within .5*. Meaning one reading is going to be say 2* the other end should be -2*. If you have more than 1* difference it's going to eat u-joints.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 05-22-2006, 08:36 PM   #5
RANDY COX
RANDY COX's Avatar
me either.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-27-2006, 09:16 AM   #6
Yukon Jack
Yukon Jack's Avatar
I had to add a CV joint on my front driveshaft when I did my initial 4" lift on my 69 K20. It has a Rockwell T221 transfer case.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
