05-20-2006, 06:17 PM | #1 |
Guage Probs
Gas guage shows 1/2 full when either tank is full ('79 with dual tanks) and does go down to empty as it should. The guage works the same, no matter which tank I am on. I've got the dash apart and cleaned the contacts behind all the guages. I have not been able to find a wiring diagram to find out what is common to both guages. Maybe the tanks have a common ground?? or ??? I also reseated the connector on the tank switch. Also, the temp guage reads at the 4:00 position as soon as I turn the key on. I can, with power off, move it down and as soon as I turn the key it pops to the 4:00. I pulled the wire off the sender and it does not move when the key on. I replaced the sender and it still goes to the 4:00 when I turn the key on. The resistance on the guage I removed is 5k ohms at room temp. Am I wrong in thinking the guage is what it's got to be now??? The speedo is int. also, but I believe that's the upper cable prob. Any help on this would be great. My wife doesn't understand why she needs to keep replenishing the garage fridge and nothing getting fixed...
05-23-2006, 12:54 AM | #2 |
Re: Guage Probs
got both gauges fixed...the shunt on the back of the gauge was bad. For gauge probs check out this site http://www.fix-a-gauge.com/index.php
05-23-2006, 09:27 AM | #3 |
Chance
Re: Guage Probs
Nice place to fix problems like that.
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
