05-21-2006, 11:39 PM | #1 |
Chance
Rear Gas Tank Install help!!!
Could anyone who knows how to install a rear gas tank in one of our trucks please give me a hand? I need to know how to mount the tank and where to run the lines. There are about 4 or 5 openings on my tank and I haven'r a clue on how to get started. Pictures would help a great deal.
Chance
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
05-22-2006, 12:16 AM | #2 |
Re: Rear Gas Tank Install help!!!
what tank are you using?
common sense isn't so common anymore |
05-22-2006, 12:47 AM | #3 |
Questionable
got any pictures?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
05-22-2006, 09:46 AM | #4 |
Chance
I bought the tank from GMC Paul's a while back. It's brand new and it came with the straps and fule sender. I'll post some this afternoon when I go home for lunch. Thanks guys!
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 Last edited by cwilkie; 05-22-2006 at 09:52 AM. |
05-22-2006, 10:40 AM | #5 |
This is what I did. I blocked off the line that was off by itself on the filler neck side of the tank, I have no idea what this was originally for. I used the one next to the filler neck for my filler neck vent tube. I used a 96 silverado fuel door for my project. The line on the fuel sender goes to the fuel pump. I bought some 3/8 steel brake line and rubber hose and connected to mine on the frame before it went over to the middle of the cab for the in cab tank. The one I labeled tank vent is how I am going to vent my tank so it doesn't have a vapor lock. Some guys use charcoal canisters off of newer trucks, but I'm going to use a tank vent off of a motorcyle to vent mine. It's supposed to only open when air is "sucked in". Here's how I did my tank.
http://67-72chevytrucks.com/vboard/s...d.php?t=197895
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
05-22-2006, 12:33 PM | #6 |
Questionable
the line you blocked off is probably a return for people who are using a fuel pressure regulator.
05-22-2006, 02:36 PM | #7 |
"Ochre Ogre"
The new tanks are repops of the 71-72 emissions gas tanks. They actually vented both sides of the tank to a canister at the drivers side rear corner and then a third hose runs up to the charcoal canister at the front.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
05-22-2006, 05:11 PM | #8 |
Questionable
ok, let me rephrase that - *I* would use it for a return
05-22-2006, 11:33 PM | #9 |
A guy with a truck
'67ChevyRedneck's post is gospel. Do it that way. There are holes in the frame already for the straps. The fun part is figuring out where to put your filler neck...
-Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-26-2006, 10:39 AM | #10 |
Chance
So for taking so long. Here are the pictures. Man...I have a mess on my end here. I have to get this gas tank hooked up properly and my newly rebuilt 700r4 transmission is acting like an @ssh*le. I hope I can get this straightend out in the next few weeks. Any and all help is needed.
Chance
06-21-2006, 09:49 AM | #11 |
Chance
Ok, my tank is undercoated and mounted using 3/4in J-bolts. The ones the tank came with were a little wimpy for my taste. Anyway, I attached all the hoses to the tank and ran my 3/8 steel fuel line last night and so far so good. I am hoping to add fuel and try it out tonight. I do have two questions though. Is there any trick to installing the fuel sender to getting it to accurately read the fuel level on the gas gauge or do you just put the rubber O-ring down, then the sender and then the locking ring and lock it down? And, how do you run the wire that is supposed to go to the fuse block? I was thinking about attaching it to the taillight harness then running it through the firewall. Thanks!!
06-21-2006, 11:19 AM | #12 |
Oilfield Trash
As long as the sender came with the tank just drop it in and go, why not just take the wire from the factory tank, drop it down through the hole in the floor where the fuel line used to run, extend it to the back and hook it up. where did you end up putting your filler neck?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
06-21-2006, 11:48 AM | #13 |
Chance
The hole for the old fuel line is welded over. So My next option is trough the firewall. The bed is off the truck; however, I am going to do my best to have the rear driver side side marker light flip open. There is a thread about it on this sight. But for now I have to get my fuel tank working then figure out why my $1200 700r4 transmission won't work properly.
Chance
06-21-2006, 05:09 PM | #14 |
i had to knoch out one of my cross braces on the bottom ofthe bed because it hit the tank,so you might want to watch for that when you install the bed...
good luck
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
