'68 Clutch linkage pic
May I please ask that someone take a pic of their "properly setup and functioning" clutch linkage ... from the engine bay, looking at where the pedal-to-z-bar linkage comes out of the firewall and then of the z-bar itself ... ??? Also, may I please ask for a pic of where the z-bar attaches to the motor-side mount ... ???
If you could post them in a "Reply" to this Post, I'd GREATLY appreciate it ... Mine is sitting at an unusual angle and I'm concerned about unnecessary torque being put on the entire linkage assembly, leading to failure. I may build my own linkage with aluminum rods and spherical bearings ... will post pics, when complete. Thanks, Dave |
Re: '68 Clutch linkage pic
Welcome aboard Dave. I spent a couple of years living in Westminster CO. Nice place.
A little more detail about your truck is needed. 2 or 4wd, V8, V6 or L6? |
![]() Join Date: Jul 2004
The pivot point on the block bracket is lower than the one on the frame on my 68, so it has a downward slope to it, but the pivot points are straight across from each other, they set square with the frame front to back.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 05-24-2006 at 02:23 PM. |
Questionable
here are some pictures:
http://satellitehead.com/images/68ch...swap%20003.jpg http://satellitehead.com/images/68ch...0_SB%20017.jpg http://satellitehead.com/images/68ch...kage%20012.jpg This is for an inline 6. Can't help with anything else. Need more? Let me know. Or just hit my gallery (in my signature) and visit any one of the albums that involve L6 swap or removal.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Next project: 1970 K10
I don't have any pics, but welcome from near Fort Collins!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
not to hi-jack the thread, but shifty, what is that orange block with the circle in it sitting just above the exhaust manifold?
1969 SS 350 Camaro Sold 2008 1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's ![]() 1980 Chevy Malibu 2 dr Sold 2007 1993 Olds. Cutlass Ciera Wagon Traded 2006 2003 Saturn L200 w/5pd. D/D My list spans 5 decades with One common thread.....GM! |
Questionable
that's the ball that the Z-bar connects with. part of the clutch linkage.
TOTY 2006
![]() Join Date: Dec 1999
Shelby987 thats looks like it is a base for the heat riser.
Questionable
oh you mean THAT circle, i thiought you were talking about the thing with the ball on the end of it above the manifold pipes.
Shifty, are you running an I-6? If so, wouldn't there be a difference between the blocks and the block-side pivot balls and mounts?
Thanks, Dave |
Questionable
i sold all three of my inline engines to a fellow board member at a stupidly cheap price, so i am no longer running one.
i decided i wanted fuel injection, reliability, gas mileage...and to ditch my 3 speed. so i picked up two extra cylinders, ditched the carb, and doubled the gears in my tranny ![]() can't answer your question about the stuff you're asking - but I'm guessing someone in here can. if you don't have luck in here, try posting in the engine/drivetrain forum with a specific title - lots of guys stop in there and know their stuff!
Active Member
![]() Join Date: Nov 2005
Here are some of my 327 set up. I can take more if needed.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
#15 |
Yes, they do!!! I have the same setup on mine, so I'm thinking that I'm okay for now ... I am concerned about the "bow" of the upper linkage bar from the pedal assembly to the z-bar ... seems like it would have a tendency to bow further over time and eventually not be strong enough to actuate the assembly ... anyone have experience with that?
Thanks for everyone's feedback ... |
#16 |
Still drivin' a Rat Rod
The only problem I have ever had out of the clutch linkage in these trucks is the nut would work loose on the zbar,and it would slide forward in the frame bracket,and slowly over a couple of days the clutch would go out of adjustment.
Strange truck that one
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
