Old 05-25-2006, 01:12 PM   #1
71Dragtruck
71Dragtruck's Avatar
Be Cool radiator install.
Anybody here have a Be Cool exact fit rad ( mines a 71 GMC 1500 ), I need info on what they did to the factory mounts to make it bolt in. I just got mine and the old mounts aren't going to work without modification. Be Cool said that most people just have to enlage the rubbers, I don'y think that will do it on mine. Right now I have a 4 row rad that was built from a original 3 row if that makes a differance. I don't want to cut up the original mounts if they aren't going to work, in that case I will just build new ones, if the old ones will work modified then that's the route I'll take.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 05-25-2006, 01:37 PM   #2
john
member #16
john's Avatar
Re: Be Cool radiator install.
It sounds like you built a 4 row using 3 row tanks. If that is the case then you will need 4 row upper and lower brackets. They are easy to find. Board venders carry them.
john is offline   Reply With Quote
Old 05-25-2006, 02:14 PM   #3
shifty
Questionable
shifty's Avatar
how can you tell the difference between 3 row and 4 row brackets? Is there a measurement in width?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
