05-26-2006, 11:08 PM | #1 |
383 Stroker
does anyone have a 383 in there 80's model shortbeds? if so do they perform well i know the motor does in like cars and stuff im thinkin bout building one for my 82
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842 |
05-28-2006, 10:02 AM | #2 |
No No
Re: 383 Stroker
It will do just as well in a truck as any other ride. I'm not too impressed with mine anymore it's eventually on its way out and a 454 is going back in.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
05-28-2006, 11:56 AM | #3 |
Parts and more parts
Re: 383 Stroker
I presently have a 383 stroker in the 84 GMC that I drive. It is the second stroker motor that has been in it. The first had a small venting problem, when a rod broke and made a hole in the block big enough to put your fist through. I like my stroker motor, it creates a large amount of bottom end torque and it pulls hard. I built this last one to stand up to a little more abuse than the last one, by putting in a few more of the higher dollar parts than I had before. (h-beam rods, forged crank, heavier duty valve springs, a better vibration dampener, etc...) The heads on my stroker are Dart II cast iron heads and the flow characteristics are phenominal, especially with the Comp Cams roller cam that I am running.
There is an old saying "There is no replacement for displacement", the big blocks definitely have the torque and the pulling power. I love the idea of that, however, the fuel economy really stinks and the weight is a factor, along with the cost of rebuild parts. My stroker does well on the highway (15 MPG) and will eat a Mustang for lunch and be hungry for more). It all sets with the gear ratio, tranny choice, cam and heads that you choose. Last edited by piecesparts; 05-28-2006 at 12:00 PM. |
05-28-2006, 01:44 PM | #4 | |
Re: 383 Stroker
1981 Chevy C10 350/350 combo-beater-Sold 1980 Chevy Big 10 350/350 combo-Project 2006.5 Scion xB-Daily Driver |
05-28-2006, 04:38 PM | #5 | |
No No
Re: 383 Stroker
05-28-2006, 02:14 PM | #6 |
Re: 383 Stroker
I am running a modified 700 R4 tranny WITHOUT the lockup converter. It still has the .7 overdrive, but the lockup was taken out and a 2400 stall converter was installed. I did this because the cam profile on my engine had the truck pushing itself at the stoplights while waiting for the light to change. That caused me to stumble and falter on acceleration unless I wound the truck up to 3500 or better to break off the line. I also changed from a 3.42 gear ratio on a 12 bolt posi rear end to a 3.73 gear to get the lower end gears that I needed in street driving. That curbed my overall top end, but I have still had the truck well above the 100 MPH mark. The acceleration is a blast and when the tranny shifts (rebuilt with heavier clutch packs and bigger planetary) it sets you back into the seat.
I cruise at about 2500 RPM, at 70 MPH, and it does not need a lot of fuel to jump to 100 MPH at that speed. The cam profile is a CS XR264HR-10 with a intake duration of 212 and exhaust duration of 210 at .050 / Lobe seperation of 110 / installed at 107 degrees intake center line. The intake is a Performer RPM and the carb is an Edelbrock Thunder AVS 650 with a K&N 14" air filter and Extreme top. The headers are ceramic coated Cyclones with a 2 1/2" exhaust and Flowmaster mufflers. The radiator is cooled by electric fans, so that there is no drag on the motor. |
05-28-2006, 02:43 PM | #7 |
driving is in my blood
Re: 383 Stroker
383's are nice, but once you want over 400hp it's cheaper to go with a big block. For cheap grins you cant beat the price of a 383/vortec head combo, talk about a torque monster.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
05-30-2006, 07:18 PM | #8 | |
Re: 383 Stroker
Now my new 383 is a different story
11.98 @112mph Stock suspension and little tires. Last edited by 81shavedtrk; 05-30-2006 at 07:21 PM. |
05-31-2006, 11:47 AM | #9 |
Re: 383 Stroker
hmm big block are good torque monsters but for about 5000 u can build a badazz 350 that will eat anything sht my dad has a 40over 350 dart sr2 heads .205/.160,dz302 69 camaro offroad cam dual plane intake and a holley and its pushin well over 500 and i think the total amount we have in it is about 1000 because we bought it used and rebuilt it but hes buildin a 60 over 283 with flat tops,blower with a demon carb,either 882 heads or zz4 heads with a comp cam and he wants to push about 500 or so
http://img.photobucket.com/albums/v5...ropped/sig.jpg |
05-31-2006, 12:17 PM | #10 |
yeller
Re: 383 Stroker
Something to add the the equation. Lets say you wanted a 500 HP engine, small block, big block...didn't matter...you wanted 500 HP. I big block can make that 500 HP a lot easier and work a lot less harder doing it compared to a small block making the same power. My 468 is mostly stock with ported cast iron heads, decent cam, aftermarket intake and valvetrain and it makes 515. To get a small block to do that, you might be talking aftermarket heads, beefed up bottom end, and who knows what else. Granted the price may equal out when the building is all said and done, but I doubt a heavily modified small block will last as long as a fairly stock big block. Not only that, but how many small blocks do you see in our trucks compared to big blocks? Different = cool.
Oh, one more thing...my comparison is on a low tech build...carbs and no computer controlled devices. The new engines of today blow my mind and are ultimately the way to go for durability and power IMO.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 05-31-2006 at 12:42 PM. |
05-31-2006, 11:20 PM | #11 | |
Re: 383 Stroker
That engine was assembled with no problems for 5 years. 3 of those years i was putting a 175 hp worth of nitrous to it putting up into high 600hp range and when i pulled it apart, the engine still looked new on the inside.
11.98 @112mph Stock suspension and little tires. Last edited by 81shavedtrk; 05-31-2006 at 11:22 PM. |
06-01-2006, 02:32 PM | #12 |
No No
Re: 383 Stroker
The BB SB weight difference is meaningless unless your attempting to shave weight from somthing that only sees 1/4 mile at a time. I know what your saying all too well from the track but it's like you take you buddy for a spin in your truck and notice a huge reduction in power. We know this doesent happen unless you stuff 9 drunk chearleaders in a claped out Celica and it wont go above 40. Notice 3 winks and 9 girls .
A BB is better suited for building a power plant in almost any situation. Cubes are cubes and the engine with the ability to suck down air and fuel at a greater rate will always make more power per revolution. This is why you almost always see amazing tq numbers with very mild BB builds.
06-01-2006, 02:50 PM | #13 | |
yeller
Re: 383 Stroker
I have $2600 into my BB, it makes 515 HP, 525 TQ...no fancy speed parts, ported cast iron heads, etc. I'm going to drive it...and a lot. Not trying to argue, I stand by my statement. Both BB and SB have their advantages...I just prefer the simple power you can make from a very mild BB, compared to the steps you have to take to make a SB perform equally. I also like to see something other than a small block when I open my hood...everybody seems to have a small block in their truck. Hell, I'd be happy with a hopped up 6 as opposed to a SB. But again...thats just me.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
06-01-2006, 06:44 PM | #14 | |
Re: 383 Stroker
11.98 @112mph Stock suspension and little tires. |
08-16-2010, 09:03 PM | #15 |
Re: 383 Stroker
ok back to this old thread how are yall getting 15mpg on the strokers? carbed?? gears im guesing??
anyway im thinking about going ot a 383 again for the 82 out of a vortech block i can get the full vortech engine for 600$ and then rebuild it i once had a site for stroker kits for around 750$ or so but lost it
08-16-2010, 09:20 PM | #16 |
Re: 383 Stroker
Running a 650 carb for streetability. Yes, I know that a 750 would make it top out better, but that is not where I drive it the most. I wanted something that would allow me to drive around highways and cities and not bog out the engine and overgas it. I would like to put an EZ EFI setup on it and see what the engine would dl for mileage and then the top end.
I also run a 700 R4 tranny W/O the lock up converter with a 2400 stall. The rear gears are 3.73s and the tires are 28" tall. I run at 2500 RPM at 70 MPH and that works great with the cam and stall converter. It still has plenty of bite to pull anyone on the road and works well in the hills. Took this on the Power Tourk, this year, and put 3000 miles on it in 8 days.
Frank Last edited by piecesparts; 08-17-2010 at 07:08 PM. |
08-16-2010, 10:08 PM | #17 |
Re: 383 Stroker
well i want it decent mpg it wont be a dd but still. ive got alot of thoughts running thorugh my mind right now. sould i use a vortec block or get a 5.3 an do a 383 with it? ya know its hard to make a real decision
but i want a darn 383 lol ive got an edlebrock performer rpm manifold and a holly 650 that needs rekitting an a th350 for now
08-17-2010, 09:26 AM | #18 |
Re: 383 Stroker
Hello Crazyjester
I have a 383 in my 82 swb and I love it I have a blast blowing away Ford mustanges and some Mopars For my tranny Im running a Hughs Turbo 400 I do need to change gears in the rear end I dont race my Truck but it is fun when I get some one toying with me after Im leaveing A carshow had that happen twice LOL Take care Jeff Main |
