FUEL CELL GURU
Finally...more quality time spent with the Blazer...
Well, now that we are somewhat organized in our new shop addition, I finally got to work on the Blazer. The progress for the last day and a half goes as follows:
1. Cut all rust out of the firewall, welded new patch panels in (including the factory a/c holes), primed and painted the entire firewall. 2. Dropped the engine in for the motor mount mockup. 3. Made a new frame mounted bracket for the Panhard bar. 4. Removed all the glass from the top, cleaned the glass, tinted the glass, and re-installed it. Hopfully tomorrow, it will be next door at the frame shop getting a little tweaking in the rear. I still need to strip and paint the spindles and brake hardware and install the new p/s gearbox and tie rods. Later, Mark |
FUEL CELL GURU
Re: Finally...more quality time spent with the Blazer...
Here's a before fiewall shot...
Looks good!
Big Block
Looks like it starting to come together. Great job. Firewall is looking good. Keep posting pictures. Great motivational tool.
FUEL CELL GURU
Thanks for the kind words. Of course many know, and some do not, but this is how it all started out....
SKINNY TIRES RULE!
Nice. What are you going to run for heat/air? I really like the color and the moldings.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#7 | |
FUEL CELL GURU
I am going to run Vinatge Air (or something comprable) front and rear. |
Looking good man. I can't wait till I have the money to go find a blazer or jimmy.
67 Chevy C10 swb-project 84 Chevy Silverado lwb-daily driver Owner-Heavy Metal Autoworks |
![]() Join Date: Feb 2000
Good to see the progress.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
SKINNY TIRES RULE!
Did you do a frame swap or convert the 4wd frame?
FUEL CELL GURU
I bought a 2WD blazer frame from board member ChrisH. It was a godsend. Easy conversion.
The LuvShack Garage
Awesome
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Sweet glad to see progress..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Epoxy Primer Friendly
Glad to see it's going places ! Looks good, are you going to bag this one ?
#15 |
FUEL CELL GURU
I wasn't planning on it but now that you pointed out all the photos of my old 68 floating around the net, I might (only lower). I know that the reason I sold the truck is because I got tired of the color but I could have painted it...it does still look pretty good. I do miss it. I must press on with the one I have now though. Thanks for the heads up on the old 68 though. Later, Mark
#16 |
The LuvShack Garage
I always liked that old truck
#17 |
![]() Join Date: Apr 2004
Nice truck! I love the stance, but that color reminds me of a taco for some reason.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#18 |
69fatmotor
looking good.
#19 |
FUEL CELL GURU
Wow, it has been a while. I have got some more progress on the Blazer. I will need to go take a slew of pics to catch up. It won't be long before I will be driving it. I am currently trying to figure out the correct brake caliper to use on the Blazer. Apparently, the 2WD frame had the brake hard line to soft line behind the crossmember. My soft lines are too short to reach the attachment location on top of the caliper. Using the calipers with a more central location should be the ticket. I'll get some pics soon. Any input on the brake issue would be appreciated. Later, Mark
#20 |
FUEL CELL GURU
BTW,
HAS ANYONE SEEN MY OLD TRUCK?? Thanks, Mark |
#21 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Hey Mark,... my '71 2wd has the steel line connect to the rubber line on the front side of the crossmember ('71-'72 connects here)
The '67-'70 trucks connect behind the crossmember. The weird thing about my blazer,... is that I have metal tabs in both places. Anyway,... I've been searching for a longer rubber line also. Since I bagged it,... the rubber lines are really stretched at full dump. I was going to go the stainless braided hose route,... but I didn't want to spend that much cash. So I decided to use '73-'78 hoses and new calipers. (I think the '79-'87 calipers have a metric banjo bolt) I haven't installed these yet,... but the hoses are much longer. Glad to see you back on the board!
#22 |
I had SS braided hoses made when I bagged mine. The OG rubber hoses were getting kinked when I let all the air out. Not too expensive.
