05-29-2006, 09:34 AM | #1 |
turbo 400 wire ?
hello i pulled the motor and trans out of my 69 350/400 the wire that plugs in the side of the trans buy the speed cable where does the other end of it plug in thanks for any help
(If all else fails get a bigger hammer) |
05-29-2006, 09:48 AM | #2 |
Re: turbo 400 wire ?
Should be a switch behind the carb.
05-29-2006, 11:07 AM | #3 |
its all about the +6 inches
Yep, a switch on the carb, and if you were dealing with a 71 & up, it'd be on the throttle pedal.
05-29-2006, 05:17 PM | #4 |
what kind of swith does any one have a pic and the name of the switch thanks for all the help
05-29-2006, 08:32 PM | #5 |
Cantankerous Geezer
I think it's called a throttle kickdown switch. The mounting varied, depending on the year, engine and carburetor. I'm putting up a pic of mine, but the bracket has been modified to fit on a Holley carb. This switch works with the vacuum modulator determines when your tranny downshifts.
Fred There is no such thing as too much cam...just not enough engine. |
05-29-2006, 08:36 PM | #6 |
Since you have a 69, the TH 400 "Kickdown Switch" will look like the one in the picture which is mounted to the rear stud of the carburetor on the Q-Jet.
There are only two wires hooked to the switch; a power wire and the wire from the detent switch on the transmission. The wires are yellow in the picture. Jm |
05-29-2006, 09:19 PM | #7 |
Uncle did you ever find that switch and wiring?
05-30-2006, 12:42 PM | #8 |
Cantankerous Geezer
If you don't have the switch or bracket, the best option besides trying to find used is to replace the pedal and linkage from a 71-72. This puts the switch inside the cab and gives you a throttle cable instead of the rod linkage.
05-30-2006, 04:51 PM | #9 | |
There's aftermarket solutions for this problem. |
05-30-2006, 11:55 PM | #10 |
does any one sell the switch that bolts to the carb
06-01-2006, 09:48 PM | #11 |
Most Camaro dealers sell the bracket. Dealers like Rick's First Generation, Classic Industries, D&R Classic, etc... They may even sell the solenoid plunger.
06-01-2006, 11:04 PM | #12 |
Active Member
I believe Lokar makes the switch.
