05-31-2006, 02:20 PM | #1 |
Be Cool Radiator installed (pics)
A few members have been posting lately about aftermarket radiators. I finished up installing my Be Cool rad last night. I had to do a bit of modification to the stock brackets to make it fit. Nothing major, alot less than I thought I was going to have to do to begin with, just opened them up with a grinder. Worst part was geting my fan setup to fit with the BB and long water pump combo I run.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
05-31-2006, 03:48 PM | #2 |
Yeah baby!
Re: Be Cool Radiator installed (pics)
More great information! What part number is the rad? Are they big block rad brackets? Have you modified the frame? I can't see the front v plate 'spreader' in the chassis. I took mine out and welded in a k tube to stiffen the frame. I run more engine set back so it will be easier to fit a big rad.
11.37 @116 |
05-31-2006, 04:16 PM | #3 |
The LuvShack Garage
Now that's tight
05-31-2006, 04:18 PM | #4 |
It is a part #60058, it is a exact fit model for our trucks, this one does not have a internal tranny cooler. The brackets I had were for a 3-row stock rad, I had turned it into a 4-row and ran it with the same brackets. Yes my cross member has been removed and replaced with a tubular one under the rad support.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 05-31-2006 at 04:21 PM. |
05-31-2006, 09:43 PM | #5 |
Junior Member
Nice work......two questions thou. I hardly ever see it done but can the fans fit in front of the radiator to give you more room? Also, I see you are not using that 3" piece of hose from the water pump to the intake manifold, will that cause any cooling problems? Thanks ......Flat 67
05-31-2006, 10:13 PM | #6 |
You could use the fans as pushers, but they are alot more efficient as pullers. My truck doesn't see very much street driving, maybe the odd spin around town. I asked around about the hose, and didn't really get a straight answer as to it's purpose, so I took it off to see how much differance it made. I really didn't notice any, but maybe someone with more of a daily driver has tried without. It maybe warms up to operating temp faster now, but I also went to a perfomance themostat at the same time?
06-01-2006, 12:18 AM | #7 |
nice! can you tell me where i can get one for under 600.00?.....thanx,dave
1971 K5 CST Blazer 1951 -3100 5 window short bed 4sp 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
06-01-2006, 12:51 AM | #8 | |
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs Last edited by 71Dragtruck; 06-01-2006 at 12:57 AM. |
06-01-2006, 01:00 AM | #9 |
yea,thats what i have found 600.00 + shipping..guess the mortgage will have to be late this month! hehehehe.
06-01-2006, 01:58 AM | #10 |
Looks good. Let us know if you see a temp difference using this. What were you running before? Thanks
06-01-2006, 12:54 PM | #11 |
I just installed a new Ultra Lite temp gauge, so I'll let you know what it runs now when I drive it next. Not sure what it ran before, just had the stock gauge hooked up. I know, expensive motor and stock gauges? Slowly replacing them as time permits ( I HATE WIRING ). Be Cool say's something like 20* cooler or your money back, think that's what it is. It's supose to be rated good for up to 1000HP with they're electric fan setup. All I know is It's alot lighter, and one big ass rad.
06-03-2006, 03:40 AM | #12 |
Why use the long water pump vice the short wp? I see that it allows for all the accessories to be completely in front of the block. Purpose?
Beautiful engine bay, btw. Stunning BBC! Got a little tip. First, you ground 3-row rad brackets to fit?? Buy some 4-row rad brackets, for crying out loud! (Not the tip. ) I bought some 4-row rad brackets from LMC way back. They came galvenized silver. I thought you might like to know since they would blend well with the alum rad. Won't blend then with the core spt, though. Personal preference rules.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
06-03-2006, 02:40 PM | #13 |
I had 2 days to install, and being from Canada, venders that have parts like that are more rare. I have a few odds and ends to get over the next month, so I'm going ask about the 4-row brackets then, in their cataloge ( Scott's Super Trucks ) they only list different rubbers not brackets. So to get the job done in the amount of time I had to do it, ( no time to wait on parts in the mail ) I ground what I had out, and if it ruined them I could have gotten a replacement set for free here in town from a local. More than likely what will happen in the end is I'll build a set out of aluminum, that sit nice and flat against the rad and support, and won't have the mounts for the plastic shroud sticking up. As far as the long water pump, If I were buying all new again all at once, I would have went with all March stuff for short pump or electric pump. But as it worked out, I was all set up for a long pump with my pullies and brackets, the only new part of the rad install was the rad.
06-04-2006, 04:17 AM | #14 |
Understandable. Thanks for taking the time to detail that out.
06-04-2006, 07:39 AM | #15 |
1970 GMC
Wow, that looks very nice.
MadDog's Website |
06-04-2006, 10:48 AM | #16 |
Can you get that radiator with different size inlets? I'm running a 5.3/4L60E and it has 1 1/4 inlets instead of the 1 1/2.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-04-2006, 11:41 AM | #17 |
Not to sure on that one, guy would have to call BE Cool. Wonder if you could come up with a different hose for it, some I've seen are a different size on each end.
06-04-2006, 11:43 AM | #18 | |
06-04-2006, 12:04 PM | #19 | |
I used one for the lower hose on my 68 when I swapped the original 2-row radiator for a 3-row 'high-efficiency' that was from my 78 elcamino. The lower radiator outlet was a different size vs. the 6cyl's water pump outlet. I used the reducer to adapt the hoses (bottom/water pump end of the hose is stock 68; top/radiator end of the hose is stock 78 camino). Worked for years w/o issue & cost was less than $5.
06-04-2006, 01:47 PM | #20 |
71
Hot , er cool swap . Looks great , like everything else in that engine bay . I'm jealous. 409biscayne.
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
02-27-2008, 06:23 AM | #21 |
ran out of money
71dragtruck, where did you get the electric fans from and also what modifications did you have to make to them to fit well? im trying to find a way to keep my bbc in my 71 cool and i also have a long water pump.
thanks for the input simply an amazing truck you have!!! great work!!
Modify everything, leave nothing alone!~ |
02-27-2008, 07:12 AM | #22 |
i was once told that the little hose from the intake to the pump is to bleed off pressure at higher rpms and not let the coolant push too fast, same as the small extra hole in the pass. side of a small block water pump. not needed with an electric pump as water speed and pressure is not affected by engine rpm. Dev.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
02-27-2008, 08:43 AM | #23 | |
18 Till I Die
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
02-27-2008, 08:40 PM | #24 |
Junior Member
I was going to run the same set up on my 72BB but after seeing the LWP set up being so close it has me wondering. I have the same radiator and have purchased most everything for the LWP set up including an aluminum water pump, chrome alternator brackets and chrome pulleys. I did not realize it was so tight. Thanks for posting.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
02-27-2008, 09:51 PM | #25 |
lookn sharp!
