Anyone got a Edelbrock Pro-Flo Multi-Point Electronic Fuel InjectionSystem?
Just wondering, I bought a used system off ebay for my 402 and wanted to see if anyone else was running this setup.
~Rest In Peace~
Re: Anyone got a Edelbrock Pro-Flo Multi-Point Electronic Fuel InjectionSystem?
i had one like about 15 years ago didnt like to many bugs pops up allways messing with the timing and fuel curve just became a pain in the ass
went back to carbs
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
![]() Join Date: Mar 2003
i have one
#4 | |
I have it on my 454 and I LOVE IT!
Throttle responce is AWESOME. Now my 454 is not stock so it purrrrs and has tons of power. This is my first FI system and so far it is working great! I had a hard time tuning it so I took my truck in for a Dyno Tune and had it tuned properly. If you are thinking of buying a used Pro-Flow setup you will have to buy a new chip from Edlebrock to match your cam specs in your engine..they burn the cam specs to a chip that goes into the ECU. I would also make sure ALL the paperwork/operation manual comes with the setup along with the hand held controller. There are also alot of parts it comes with new, like fuel line, electric fuel pump, Dist convertion kit, etc... Get a parts list of a new setup and make sure the used one has ALL the pieces. .02c Good Luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
#6 | |
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod Last edited by 71RestoRod; 06-07-2006 at 07:02 PM. |
#7 | |
That is the one I bought. |
I do like mine. I had to have a pro program it. Great throttle responce but the 383 stroker still sucks on gas. but then again....my foot is quite heavy when I drive it once a week.
Looks like you got a good price.
I hope the harness was there too? I bought a new dist. from Mallory instead of using the conversion kit. Mallory makes a dist. specifically for this MPFI setup...it plugs right into the harness ![]() ![]() I also added a fuel pressure gauge. Just as a reminder use high pressure FI fuel line.. That kit is probly identical to the one on my 454 so if you have any questions just ask. Burt ![]() ![]()
Gotta love having a 454. At idle you can climb a hill.
Robk
Rob "RunTMCfan" |
#11 | |
Thanks, Kade |
#12 | |
Thanks, Kade |
Sounds COOL Kade!
I almost got Alum. Heads but I had a set of 781's so I decided to stuff them with oversized valves and run the cast..heavy suckers! The cam I am running is a CompCam pn# 11-231-3 Duration @ .05 Intake=210 Ex=218 Lobe lift Intake=.297 Ex=.297 I have a spec sheet in my qubical here at work so there are more nubmbers on it if you need more.. I think the chip is just a high level starting point..the tuning adjustments is what will make your rig run right.. When I fired up my 454 for the first time it sounded like a HUGE Harley..Bllubb......Bllubb.........Blubb ![]() I had to adjust the " Global Fuel Modifier" percentage up to 25%+ and then the engine started to Purrrrrrrrr. It was starving for fuel. Did you get an owners manual? Gotta get one..explains all the Modifiers to adjust...doesn't explain to well WHY you want to adjust them just how to ![]() If you like I can give you ALL the Modifier settings that the EFI tech set my MPFI ECU to on the DynoTune....duno if that would do you any good or not but I wrote them all down incase the memory is lost for some reason?? ![]() Also I did not use the Dist conversion kit so if you need any of thoes parts just let me know. Have fun at the show! Burt
#14 | |
Duration @ .05 Intake=230 Ex=236 Lobe lift Intake=.547 Ex=.547 part number 11-451-8, I tolf them I wanted a rough idle that would shake the fenders off. Here is what edelbrock told me to run Duration @ .05 Intake=240 Ex=246 Lobe lift Intake=.560 Ex=.573 They both said I could get by with a 2500 stall. I am supposed to get it monday and I will see what all that he included. I ordered the heads today and maybe I will get them next week and I also ordered a eaton posi and the 3.73 gears. I figure when I start putting all this on I will be down a week or two before I can get it up and running, but it should be a little tire shredder when I get done. At over $3000.00 dollars it should be. I appreciate all the help. Thanks, Kade |
#15 |
Ya Kade sounds like a runner for sure!
keep us posted as you get closer to runnin it ![]() ![]() Good Luck Burt
#16 |
A guy with a truck
Looks good. Nice and clean!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#17 |
Hellya!
![]() Nice! Thanks for the pics! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#18 |
