![]() Join Date: Mar 2003
firewall harness, what wires are these?
Sorry but no pic's on this one. I am looking for information on the harness that is located about 3 inches above the MAIN wiring harness, Just to the right of where the spedo cable exits the firewall. Looks to have about 5 wires in it. Behind the dash, it goes to a relay and the fuse box. Please help identify these wires. Goes on a 71 4x4 blazer with factory ac.
Truck junkie
![]() Join Date: May 2006
Re: firewall harness, what wires are these?
Hey there I'm in Reno too. I'm going out to look at mine right now.
here you go.
call me at 358-3722
Truck junkie
Where does that go from there the relay on the inside next to the fuse block on mine is the horn relay. I have one wire in that location and it goes to the blower motor relay and since yours has factory ac it could be the a/c/ switch relay. Mine has no air.
#6 | |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
I believe it is the harness for the TCS (Transmission Controlled Spark) system.
Basically it's an emmissions thing. My harness was still still on my truck when I got it but the TCS solenoid was gone and the circuit was not functioning. I removed that harness when I switched to TPI.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-07-2006 at 03:23 AM. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Mine went away when I put the painless harness in..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Having issues
I went and looked at the two rigs in the driveway. My '71 (build date 05/71) with AC did not have this harnass, nor did it have the dingleberry on the transmission. Engine calibration code AQ. US Dept. of N.E.W and CA. certified
![]() ![]() ![]() My '72 CST(build date 04/72) had it. Engine calibration code LM, federal and CA compliant. In the harnass there was the feed to the coil, and 3 other wires (that I noticed) that went to a plug, (whatever it plugs into is gone, no suprise there) then down to the transmission. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." Last edited by masterbeavis; 06-09-2006 at 08:36 PM. |
Having issues
On both of my rigs, one ear is broken off of each one.
![]() ![]() HEI/tach pic shown here. ![]()
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." Last edited by masterbeavis; 06-13-2006 at 04:21 PM. |
The LuvShack Garage
I have a full upgraded wiring system too, no help just a bump
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Exactly what is a "dingleberry"
![]() ![]() ![]() Shane
1993 K1500 350 5 speed ![]() 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ![]() Member#20327 |
Having issues
its a thingie used in upholstery, its a little ball on a string, commonly seen (in the old days in cars driven by mexicans, and indian (not nativie) cab drivers in NYC. Also refered to "something" stuck to hair on a nether region of your backside that has balled up. I will let you draw your own conclusions.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
