Old 06-14-2006, 09:43 PM   #1
ThatOneBlue67
I survived Dead Man's Curve.
ThatOneBlue67's Avatar
Putting a 67 body on top a 76 frame.
I am really intersted in putting my 1967 body (2wd) on a 1976 frame (4wd).
Educate me as to how I actually have the body mount. WHich mounts do I use? What kind of fabrication can I expect to be doing?
PLEASE help me out or point me in the direction of a great website ro something.
Thanks.
"The people should not be afraid of their government. The government should be afraid of it's people."
"The Hurricane"
1967 Chevrolet C10
350 Eight Cylinder, 700R4 BowtieOverdrive
Cherry Bomb... Disturbing the Peace Since 1968.
ThatOneBlue67 is offline   Reply With Quote
Old 06-14-2006, 10:00 PM   #2
dboyzalter
dboyzalter's Avatar
Re: Putting a 67 body on top a 76 frame.
I was going to do the same but I already have a 4x4 just needed a good frame... I shall point you in the right direction in a few seconds
dboyzalter is offline   Reply With Quote
Old 06-14-2006, 10:03 PM   #3
dboyzalter
dboyzalter's Avatar
this was a message I got from another member on the board... name is randy... forgot his SN... but I'm sure it will help...
Subject: 4X4 Swap
First thing to do is a lot of measureing wheel bases. This is what I
did. I used a 67 shortbed 2wheeler and a 77 shortbed 4wheeler. The wheel
base for the 67 was shorter so I shortened the frame of the 77 1 1/2
inches. Thats to keep the wheel/tires in the center of the wheel
openings. I took it out of the middle of the frame. I used the 67 cab mounts
and mounted them on the outside of the 77 chassis. (77 mounts are
mounted on the inside on the back of the cab). The mounts will go in about
the same location as the 77 mounts were. A good way to mount the cab is
to bolt your cab mounts loosely to the cab, lowering the cab onto the
frame to where you want it, then marking the location of the cab mounts.
Doing it this way you can tell how much clearence you have between the
cab and frame/transfercase/ tranny and distributor. It is very
important to make sure you have room to take the distributor out when you mount
the cab. I used a low hump cab so I had to use a body lift to get
enough height to keep the body lines of the front clip/cab and bed lined up.
I drilled new holes in the frame for the bed next after the cab was
mounted. Using some body lift will give you a lot of room to work with
making the proper adjustments. I basically used a 3" body lift but in
on some mounts it was more and the the bed was less in places. You will
be able to see the differences in the attached photos. This swap is
not really that hard if you can weld and cut steel. Ok the transfer
shifter had to be lengthened about 3". I added a small u-joint to the
steering column. If you have to shorten, lengthen frame you may have to
adjust brake lines and drive shaft. I was lucky that I didnt have to mess
with the drive shaft. Brakes. The 67 had drum brakes with a booster. All
I did was hook the lines from the 77 on the 67 booster and I have had
no problems. I recently changed over to 3/4 ton with disks and I am
still using the old 67 master and booster. The brakes work great. So dont
mess with the brake lines on the newer frame. youre gonna need them.
Used still plating for bumper brackets. The front was a little funky but
we made it work. Everything else will basically work. Its a good time to
get the tank out of the cab too. I used a pre fuel injection tank from
a blazer. Got the tank skid plate and everything for like 60 bucks.
Works very well. Use caution when removing all the older trucks wiring.
You're gonna be using it again. The wiring for the front clip will just
unplug at the firewall, but the wires going to the back have to be
taken off of the frame. I will send you my phone number with these pics
just in case you decide to do this swap. I work nights. Thats all I can
think of right now. You will be able to see by the front clip mounts how
we did it. really sinple and easy.Hope this all helps. I tried to cover
everything.
Old 06-14-2006, 10:03 PM   #4
ThatOneBlue67
Sweet, that'd be awesome.
"The Hurricane"
1967 Chevrolet C10
Old 06-14-2006, 10:28 PM   #5
dboyzalter
dboyzalter's Avatar
mudder 67 has it done on his truck... (wich is pretty sick) and he is the one who wrote that...
Old 06-14-2006, 10:47 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Yeppers, Mudder's the Man
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 06-15-2006, 12:40 AM   #7
ThatOneBlue67
Yeah.... that all looks good except having to shorten the wheelbase. That alone is makin' me wanna stay 2wd and just drop in a V8. I'd buy a 4wd 67-72 but not only are they rare over here, I've already put to much into the Hurricane to just sale it off.
"The Hurricane"
1967 Chevrolet C10
Old 06-15-2006, 06:10 AM   #8
Mudder
Mudder's Avatar
Man I can't belive I wrote all that, and you know I have probably sent that along with a few pictures to over a hundred requests.
Mudder is offline   Reply With Quote
Old 04-20-2011, 07:33 PM   #9
69toner
mudder how bout making it 101 I have 1969 one ton and want to install the cab and flatbed on A 1977 one ton, big block auto. trans have read most of what you have written, do you still have pictures of your mounts? Would like all the info I can find before I start the switch. Thanks, My E-mail is gmlkmoo@msn.com
69toner is offline   Reply With Quote
Old 04-21-2011, 11:32 PM   #10
72 K20
72 K20's Avatar
I would also like to see your pictures of this swap !!
I am going to put a 72 longbox on an 84 longbox 4x4 frame and any and all tips or insight would be great !!!
X.475@hotmail.com
Thank You !!
Tom
72 K20 is offline   Reply With Quote
