06-15-2006, 08:02 AM | #1 |
Wiring through door to spkrs, pwr windows..
I need to get some wires through to my door for my speakers and for power windows. What all have u used? Im guessing some kind of grommet. Where is a good place to find them?
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
06-15-2006, 09:51 AM | #2 |
Re: Wiring through door to spkrs, pwr windows..
http://www.a1electric.com/Merchant2/...Category_Code=
This is what I'm using. They also have these: http://www.a1electric.com/Merchant2/...Category_Code= Last edited by ChevyDude; 06-15-2006 at 09:52 AM. |
06-15-2006, 09:58 AM | #3 |
Next project: 1970 K10
When I was building conversion vans, I used these when adding power door locks, door speakers, etc. Nice and clean, and no wires! You can get them in 1,2,3,4, or 5 contacts too. Only bad thing is they obviously won't work when the door is open.
http://www.painlesswiring.com/partse...p?editid=40024
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
06-21-2006, 12:23 PM | #4 |
Or if you want to get really fancy
http://www.thehoffmangroup.com:16080...itemid=DLOOMBL |
06-21-2006, 12:30 PM | #5 | |
06-21-2006, 09:38 PM | #6 | |
Granddad's Ol' Truck
1971 Chevrolet Custom 10 short step-side 2005 GMC Sierra SLT 2500HD crew cab 2wd [I]1971 Chevrolet Custom 10 Deluxe lwb fleet-side |
06-21-2006, 12:35 PM | #7 |
Oilfield Trash
went through this on my truck, the ones that woodz72 has mentioned probably would work but you would have to cut some kinda of access hole in the kick panel to screw the nut onto the backside of it
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
06-21-2006, 12:39 PM | #8 | |
06-21-2006, 12:43 PM | #9 |
Oilfield Trash
Well even if you had the doors off you could do it, just cut a hole in the outside of the kick panel, and insert a rubber plug in when you are done.
06-21-2006, 05:28 PM | #10 |
I used these.
http://www.a1electric.com/Merchant2/...Category_Code= |
06-21-2006, 05:30 PM | #11 | |||
Union Electrician
I thought that no matter what you use you still have to drill the inner kick panel right? Aren't there two seperate panels there with a gap between them or am I just goofy??
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
06-21-2006, 06:12 PM | #12 |
I drilled holes large enough for a small rubber grommets.
I bundled the various wires together (my wiring was for component speakers mounted in the lower part of the doors) & put a piece of heat shrink tubing over the 'bundle'. The heat shrink tubing had to be long enough to go from the interior/cab to the exterior/door. Once heated, I had one solid black bundle of wire that I inserted through the grommets (one grommet in the door jamb; one grommet in the cab jamb; one grommet in the inner cab kick-panel). I made sure to size the heat shrink tubing & the holes in the grommets so that there wouldn't be a bunch of slack after installation. It was tight enough that I needed dishwashing liquid-soap to slide the heat shrink/wire bundles through the 3 grommets. It gives a clean, simple routing that looks like it came from a newer model vehicle & it's pretty cheap to do.
06-21-2006, 06:59 PM | #13 |
Oilfield Trash
chevyboy, could you post some pics of your install? would like to see where exactly you fit those in
06-21-2006, 07:46 PM | #14 |
Blue
The wire in the pics is for the power door locks/keyless entry/alarm loom. I had to drill a rather sizeable hole for the rubber boot. I think it was 1" or 1 1/4" The only speaker wires we ran is from the 2-4" speakers in the dash.The 6"x9"'s are going to be mounted in the rear corner of the cab where the gas tank was. I am glad you asked for pics I see I need to remove the speaker wire from when they were in the doors. Hope this helps. If you need more, holler. Last edited by chevyboy55; 06-21-2006 at 07:54 PM. |
06-21-2006, 08:18 PM | #15 |
Oilfield Trash
Thanks man, thinki'm gonna pick up a pair for my power windows someday, guess i'll have to take my doors back off to intstall them
06-21-2006, 08:26 PM | #16 |
Why couldn't u just use the boots off a mid 80's chevy truck they have a flange that can rivet on and look factory? just my 2 cents
06-21-2006, 08:40 PM | #17 | |
when I got the alarm/keyless entry stuff for my son for Christmas & they made a good stocking stuffer. |
06-21-2006, 09:25 PM | #18 |
Oilfield Trash
Can you buy reproduction ones for the mid 80's?
06-21-2006, 10:07 PM | #19 |
Oilfield Trash
Subtle, how did you get inside the kick panel to tighten the nut? Also which end did you make slide? I bought a pair of those ones put figured they would be a hassle to install
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. Last edited by Blue85; 06-21-2006 at 10:09 PM. |
