06-17-2006, 12:06 PM | #1 |
TPI vs carb
can someone give me the pros and cons of each? is it as simple as getting off an old camaro and slapping it in? i have a newer gen crate 350.
'72 K5 CST Blazer 4x4 in perpetual progress '96 2dr Tahoe 4x4 daily driver, Black Bear Performance tune, 285-75-16 Nitto Grapplers, Magnaflow muffler, K&N Air filter, Bilstein Shocks.........E-fan, DT Tri Y or Pacesetter LTs coming soon |
06-17-2006, 02:44 PM | #2 |
Re: TPI vs carb
Makes a nice street setup but a lot is involved in setting it up. (wiring in the comp., adding sensors, adding high pressure pump and return line and welding in oxy. sensor in exhaust.)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
06-17-2006, 02:51 PM | #3 |
Re: TPI vs carb
slap it in? Not quite, but's it not impossible either. I did it, and I'm not a pro at this stuff. There are a ton of threads on it here, do a search. Also check out www.jagsthatrun.com and www.chevythunder.com
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
06-17-2006, 09:31 PM | #4 | |
Active Member
Re: TPI vs carb
I did it last summer and it took me a while but I love it. Cold starts are great (although I converted from a manual choke Holley) and the low end torque is excellent. If you do any offroading, it's definately the way to go. If you decide to go for it, do your research first and make sure that you get a COMPLETE setup for a 350. Don't be afraid to ask lots of questions and check out www. thirdgen.org. It's a Camaro/Firebird site and the guys know their stuff about TPI. Besides, I think it gives your truck that extra "Wow" factor when you pop the hood.
The rides: '72 Blazer 350/4spd/Tuned Port Injection '69 Firebird 400/4 speed 2001 Dodge Dakota Sport 4X4/4.7L V8/5 spd/Headers/Jet Chip, etc. Daily Driver 2002 Airborne Zeppelin (roadbike) Titanium frame/Campy Chorus 2004 Filippi Italia S (rowing shell) |
06-17-2006, 10:41 PM | #5 |
Re: TPI vs carb
I put a TPI 383 in the old truck and after hearing it run (Haven't driven it yet.....doing suspension now) I would never go back to a carb. throttle response is awsome,and it starts like a dream.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
06-17-2006, 10:43 PM | #6 |
Re: TPI vs carb
I also moved the battery to the frame on the pass side to make a functional cold air intake.
06-18-2006, 12:30 AM | #7 |
Re: TPI vs carb
so how much is a complete setup usually?
06-18-2006, 02:35 AM | #8 |
Active Member
Re: TPI vs carb
Just curious where you guys put your computer. My Jimmy has factory A/C so i am not sure if it will even fit under the dash with all the extra hoses and vents. I am hoping to be able to do this soon, so any info would be helpfull.
Mike T. Oregon 70 GMC Jimmy 4x4 70 Camaro LS1 plans in the works 71 RS/SS Camaro numbers matching 86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear) |
06-18-2006, 01:21 PM | #9 | |
Re: TPI vs carb
06-18-2006, 03:06 PM | #10 | |
Active Member
Re: TPI vs carb
06-18-2006, 07:44 PM | #11 |
Active Member
Re: TPI vs carb
I already have a Street & Performance harness that is extended so i may just mount it under one of the front seats. To do that i may have to make a hole in the floor otherwise the harness would show under the carpet. I was going to go with a modified LT-1 manifold and decided to go with the earlier TPI manifold instead since i was after torque and not top end power. Has anyone installed one of these on a SBC 400 yet with success. I am also going with a speed density system since i heard that they are a little more forgiving when it comes to modifications to a motor.
06-18-2006, 11:02 PM | #12 | |
Re: TPI vs carb
06-19-2006, 11:20 AM | #13 | |
Tpi72Blazer
Re: TPI vs carb
Indian - the other money pit |
06-18-2006, 02:06 AM | #14 |
Re: TPI vs carb
You can find them on Ebay where they "claim" to be complete for $300 - $500...but they aren't complete. I bought a whole car and that's how I would do it again. I knew it ran before I started, so that helped when I had to chase gremlins. A complete one will have everything, the harness, computer, distributer, injectors, 02 sensor, knock sensor, relays, etc. I think it's so much easier to start with a whole car though, that way you know that it runs before you start.
06-18-2006, 07:33 AM | #15 | |
Re: TPI vs carb
Fairly big project but by no means impossible. IMO, I'd go with an after market wiring harness, not a complete car. Reason being is with an A/M harness, you'll only need power it and install the sensors. (short version) A stand alone brain will be way easier as well. Do the research for sure, there's lots to learn before you jump in. For me, it's wheeling the steeps. No carb, no stumble...stumble on the steeps bites. |
06-18-2006, 08:55 AM | #16 |
Re: TPI vs carb
vtblazer is on the right track IMO, but I would do both. Get you a complete car so that you know you have all of the pieces/parts. Then buy the aftermarket wiring harness. You can sell the body to help offset your investement. I bought an '86 305 TPI Trans Am for $1275. After pulling the motor and all the FI parts as well as the TH700R4, I sold the car for $1000. I'll swap in an extra set of LT1 injectors instead of the 18lb 305 ones and am planning on controlling with a DFI box.
06-18-2006, 10:49 AM | #17 |
Re: TPI vs carb
Agree with all that has been said (and definitely buy a complete car: http://67-72chevytrucks.com/vboard/s...44#post1706244 ). I've done all 4, TBI, TPI, LT1 and now a 5.3 vortec (2006 Tahoe). Fuel injection is hard to beat for horse power, dependability and gas mileage. It's more work setting it up, but you will appreciate it afterwards. I've used a Painless Harness, Howell Engineering and a Street and Performance one. Quality and ease of installation is about the same with all of them. Pick one you like after doing some more research.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-18-2006, 10:55 AM | #18 |
Re: TPI vs carb
one tpi is better for bigger cams than the other isnt it ?
06-18-2006, 11:13 AM | #19 |
Re: TPI vs carb
If you are going to change from stock, you need to use a MAF (mass air flow) system, vice a MAP (manifold absolute pressure) system. MAF actually measures incoming air, MAP uses preprogrammed values. Some aftermarket systems (holley projection?) will allow you to make adustments to match your engine.
06-18-2006, 11:18 AM | #20 |
Re: TPI vs carb
so tha maf is better when using bigger cams ? was that the early years or the later years ?
06-18-2006, 11:22 AM | #21 |
Re: TPI vs carb
Both, early had MAF, then they went to TBI and later they went to MAF & MAP. Not sure which years.
Rob
06-18-2006, 01:19 PM | #22 |
Re: TPI vs carb
In canada I believe MAF was 85-89.
06-18-2006, 08:55 PM | #23 |
Re: TPI vs carb
I believe MAF gives you more ability to modify the motor. MAP sensors are specifically designed for a give engine, cam, HP..... Whereas MAF, make adjustments based on the actually airflow required by the engine. Here is some more information.
http://www.carcraft.com/techarticles/24549/ http://67-72chevytrucks.com/vboard/s...ad.php?t=52057
