06-19-2006, 09:49 AM | #1 |
Never Done?
Best tools for cutting c-notch?
Other than a plasma cutter (left mine in my other pants), what do you guys recommend for cutting the frame for a c-notch?
06-19-2006, 10:22 AM | #2 |
67 is sold
Re: Best tools for cutting c-notch?
sawzall
06-19-2006, 10:57 AM | #3 |
i use a jigsaw with a bimetal fine tooth blade for that type of stuff
06-19-2006, 10:58 AM | #4 |
Fat Fendered Fleetside
^ + eleventy billion.
Sawzalls are great! you could always use a gas torch too! (but sawzall leaves a nice cut, not chunky slag that needs to be ground(like plasma and gas) but I guess you'd want to grind anyways, if you're preping to weld it together |M|
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
06-19-2006, 01:08 PM | #5 |
I've heard of guys using a hole-saw. Seems like it would be the perfect tool for a c-notch if you are using round tube.
06-19-2006, 01:15 PM | #6 |
problem with sawzall is cutting a nice even contoured rounded hole// can use a hole saw PITA tho to cut half holes
06-19-2006, 01:23 PM | #7 |
Never Done?
Guys, I appreciate the faith you all have in me but this c-notch will be a bolt-in. I can't weld... there I said it! Thanks for all the tips though. I might try the jigsaw out seeing as I own one of those already.
06-19-2006, 01:31 PM | #8 |
Oil the blade periodically while you are cutting and the jig saw should work fine for you.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
06-19-2006, 03:00 PM | #9 |
Outlandish Trends - FL
I just did mine yesterday. Here's what I did.....
First I scribed the line I was going to cut, then in the upper two corners I used my Unibit (step-bit) and drilled holes there. You want to keep the upper edges rounded to eliminate possibilities of spider cracking in the corners. Then, I broke out the sawzall and started at the bottom and made my cuts up to the holes I drilled. From there, I just used a cut-off wheel to cut the horizontal line between the 2 holes. Cutting for the notch is the easy part!! The PITA was all the rivets you need to get out. Some are hard to get to with the air chisel.
-Bret 67 short-fleet sold! |
06-19-2006, 08:29 PM | #10 |
For the first several that I did all I used was a .040 thick cut off wheel on a 4.5" grinder. I also used this for cutting off teh riviot heads before beating them out with a single jack and a big drift. Works great but now I use a Plasma and when operated right their is no slag to grind off that is what is so nice about them
Kevin LFD Inc. |
