06-20-2006, 12:31 AM | #1 |
Engine idles up and down, old owner say its converter?
Just bought 94 suburban with 175k and runs good but idles up and down when in park, never quits or comes close just sounds weird. Any ideas?
Also does a weird like scraping sound when drive forward or reverse for first 5 minutes of driving. Any ideas? |
06-20-2006, 01:17 AM | #2 |
Truck junkie
Re: Engine idles up and down, old owner say its converter?
In most cases an engine searching at idle has to do with the tps. make sure the ac compressor isn't kicking on and off in sequence with the idle going up and down too. I would definitely get it to a transmission shop and have the trans checked out...when I busted the sun shell in my 01 chevy it made a noise like that for a few weeks and eventually because I didn't get it checked out I had to buy a new trans I don't know exactly what finally happened but it wrecked the case so it wasn't a good core. I don't know that this is a problem for your truck and it may very well be a torque converter problem but definitely have a transmission shop or someone that knows trannys have a listen. Hope you get it worked out.
06-26-2006, 11:22 AM | #3 | |
06-20-2006, 01:56 AM | #4 |
Gone Fishing
Welcome to the board
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
06-20-2006, 02:00 AM | #5 |
Thank you for the advice and I will do that. Really glad this site is here as I am a novice when it comes to fixing anything beyond having to use a hand tool as no garage or heavy lifting equipment for engines and such.
06-20-2006, 02:09 AM | #6 |
Truck junkie
Welcome to the board. There are tons of great people here with knowledge in just about anything that has to do with chevy trucks.
06-24-2006, 02:21 AM | #7 |
Captain CAAAVVVMMMAAANNN!
hunting or low idle could also be a stuck open egr valve. something to check, I just ran into this about 2 weeks ago.
72 LWB Fleetside C10 Custom 350/350 97 GMC Yukon 4X4 SLT Anna, Texas check out the project old yeller |
06-24-2006, 10:34 AM | #8 |
Here are a couple more things to consider: Check for vacuum leaks, especially the gasket under the TBI (throttle Body Injection) unit. It is possible the IAC (Idle Air Control) is starting to fail. Here is where the IAC is located on the rear corner of the TBI. |
06-24-2006, 11:53 AM | #9 |
your IAC could be clogged with carbon , pull it off and clean it with carb cleaner also spray some in the opening where it mounts. wait a while for the cleaner to dispurse before starting your truck
07-04-2006, 04:00 PM | #10 |
Hello all. I have been having a similar problem with my 89 chevy. It runs great in gear, but idles up and down in park. Has a new engine. Have replaced computer, tbi, iac, fuel pressure regulator, all sensors, distributor, cap, wires. Have replaced everything I can think of. Have removed catalytic converter just to see if that was the problem. Still no change. I'm at my wit's end. Any ideas, suggestions, etc. would be greatly appreciated.
07-04-2006, 09:43 PM | #11 |
Hi HotRod Chevy.
I see it's your first post, so welcome to the board. If I were working on your truck the first thing I would do is get it up to operating temp and look at the IAC count with a scan tool. I would like to see it low but not zero. Off the top of my head I believe the desired range is a count of 1 - 50 Next I would look at the integrator and block learn counts to see where the fuel mixture is. I would also look at the o2 sensor reading. Do you have headers and a one wire o2 sensor that is running to cold at idle? Last edited by ChevyTech; 07-04-2006 at 09:51 PM. |
07-05-2006, 10:32 PM | #12 | |
07-06-2006, 10:04 AM | #13 | |
Integrator is fast or short term fuel trim – computer fuel adjustment currant setting - determines fuel injected. HotRodChevy you have replaced so many parts, at this point it would be a good idea to find someone with a scan tool and experience using it to determine why the idle is not being controlled. Here are some possible causes: IAC sticking / binding or failed IAC passages in the TBI plugging up Lean mixture Vacuum leak – check your hoses and TBI base gasket Minimum air rate out of adjustment. Bad information to the computer from a failing sensor. With all HotRodChevy's new parts he has eliminated most of the possible causes. Last edited by ChevyTech; 07-06-2006 at 10:14 AM. |
