Old 06-20-2006, 12:12 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Glock and HuggerCST's official "Project 68" build thread
I thought I had better just start one thread and continue it instead of making a new one here and there when something got done. So, here it is. I will update this one as any progress is made.
So, to start the progress report, I got the engine and trans set in place last night. It is just temporary though, as I forgot to get flexplate bolts!
I mainly wanted to get them in so I could start building the exhaust system. I need to bolt up the starter, trans cooler lines, and anything else that could get in the way so I can build around them. I am thinking that I might use a Lokar shifter cable linkage setup, that will let me run the exhaust completely above the bottom of the frame.
That's all for now. I might put the bed together so I can set it on the frame to build the back part of the system. Oh yeah, that Flexfan is going away!! Have a factory fan to replace it with.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-20-2006, 12:32 PM   #2
ChevyDude
Re: Glock's official "Project 68" build thread
Fantastic!!! I'm sure you will have an awesome ride when you finish!!! Keep the pics a coming!!!
ChevyDude is offline   Reply With Quote
Old 06-20-2006, 12:37 PM   #3
matthufham
nice! keep on going
matthufham is offline   Reply With Quote
Old 06-20-2006, 12:44 PM   #4
glock35ipsc
Ya know, it's kinda funny...... I've had the rolling chassis basically done for over a year and a half now, and it's been sitting in my other garage under a tarp. Then, one day, I get my shop cleaned out and think "I have room to move the chassis up here now", and I've had a full head of steam ever since!! I don't want to get ahead of myself here, but if I can keep the momentum up.......
Naw, I don't want to jinx myself!
Bob
Old 06-20-2006, 05:08 PM   #5
matthufham
are you sticking with the ram horns?
Old 06-20-2006, 05:15 PM   #6
glock35ipsc
I am keeping them. I'm going to smooth out the casting marks and grind off the bumps, then they are getting ceramic coated.
Bob
Old 06-20-2006, 05:18 PM   #7
powell72
powell72's Avatar
You're going to run yourself out of work on that frame and then have to get back to work on that cab you know!
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 06-20-2006, 05:31 PM   #8
glock35ipsc
I know, don't remind me!! I know eventually I will have to get back on the cab, and the way things are going on the frame right now, that may be sooner than later! Oh well, at least at that point I will know I have to get the cab finished if I ever want to drive this thing again.
But, I think things will progress very quickly once the cab is done. Once that is done, it's just a matter of fit, adjust, paint, and reassemble.
Bob
Old 07-17-2006, 03:32 PM   #9
BigSky71
LAIDOUT
BigSky71's Avatar
That is exactly where I am at, frame is done, cab half done but progressing. I need to get my cab in paint while I can still paint in my outdoor "paintbooth". The window of good weather for painting in an uncontrolled environment closes in Montana at the end of August, must stay focused!
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 06-21-2006, 08:29 AM   #10
Joe67
67 is sold
Looks great! I bookmarked this thread
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 06-21-2006, 10:15 AM   #11
glock35ipsc
Cool Joe! Here's some more pics for ya then!
Last night I mocked up the exhaust on the drivers side. I had to redo it a couple of times where it runs over the axle, but I think I have it where I want it now. From there it runs outside the frame since I will have a gas tank in the rear. My wife and I both jumped up and down on the back of the frame and it never touched the axle (the shocks are not on right now either). The thing I like about it is that there will only be a couple of bends in the system. And, there is absolutely nothing visable under the frame. I like it!! I also decided to use Lokars cable shifter linkage to gain some clearance, so I could then run the pipe right through the area where all the linkage stuff was.
I am using 2-1/2" aluminized pipe along with welded mufflers from Summit. My buddy has them on his Mustang and I really like the sound of them, real throaty, and kind of like a Flowmaster but without the hollow/echo/cackly sound of the FLowmaster. Hmm, guess it sounds nothing like a Flowmaster then, huh? LOL! I am debating now whether to do the passenger side, or weld up the drivers side. I think I will do the passenger side next, and try to make it as exact as possible to the drivers side, then weld everything up.
Truck porn:
Bob
Old 06-21-2006, 10:33 AM   #12
Joe67
67 is sold
I like that exhaust setup. I think I need to put holes in my crossmember for sure now.
Are you going to have any clearance issues with your exhaust running over the rear axle like that?
Old 06-21-2006, 10:39 AM   #13
glock35ipsc
It's not as close as the pics make it look. I don't have the rear shocks on yet, just the coil springs, so the wife and I jumped up and down on the rear of the frame and we could not get it to hit the axle. If I ever decide to go lower, I may run into clearance issues then. But, if I hit enought holes and bumps, it may just 'correct' itself!
Bob
Old 06-21-2006, 10:41 AM   #14
Joe67
67 is sold
Sounds like a plan, keep the updates coming
Old 06-21-2006, 12:37 PM   #15
mike nutt
69fatmotor
mike nutt's Avatar
looking good. keep us posted on your progress.
mike nutt is offline   Reply With Quote
Old 06-22-2006, 09:20 AM   #16
glock35ipsc
Hmmmm, anyone see a problem with the exhaust in this pic?
It just jumped out at me this morning as I was loading my TIG welder cylinder.... I ran the tube right square under where the upper shock mount needs to go!! OOPS!!!! Bummer, I guess I need to install the upper brackets and the shocks, then order a couple more u-bends and route it around it.
Didn't do anything last night except for fall asleep on the couch at about 8:30!
Bob
Old 06-22-2006, 09:35 AM   #17
Joe67
67 is sold
Oops :LOL:
Here is what Stacey did on Copperhead
Old 06-22-2006, 09:56 AM   #18
glock35ipsc
Hmm, I wonder how they exit?
Bob
Old 06-22-2006, 10:24 AM   #19
Joe67
67 is sold
Here is another:
I'm thinking of dumping my exits or going out the side somehow...
I just found this website! Great pics of the buildup!!
http://www.paintucation.com/copperhead.htm
Old 06-22-2006, 10:36 AM   #20
glock35ipsc
I like it! I guess I could do that if I went with a Fuelcellguy tank, then I could just cut the front corners like that and weld them back angled. Hmmmm.....
Bob
Old 06-22-2006, 12:57 PM   #21
Alvin
Never Done?
Alvin's Avatar
If you go with a Fuelcellguy tank, you can get it made that way to save you the hassle!
Great looking truck by the way. And is it just me or does there seem to be a lot of us building chassis at this point?
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 06-22-2006, 10:40 AM   #22
Joe67
67 is sold
The Copperhead tank is a modified 'Copperhead style' Early Classic tank
Old 06-22-2006, 02:36 PM   #23
glock35ipsc
Leave it to me to overlook the obvious!
Your right, there are a lot of in-the-works chassis happening right now!
Bob
Old 06-24-2006, 12:27 AM   #24
glock35ipsc
OK, got the exhaust fixed. The front stayed the same from the manifold to the trailing arm crossmember. The rear is basically the same setup, but routed differently. This time, I mounted the upper shock bracket and shock before tacking pieces in place (what a concept!). I was able to use all of the pieces from the first try, and only had to make one new one.
I have already fully welded it except for one joint right behind the crossmember. I need to pull it out, finish bending and welding the hangers, then I will be painting the systen with aluminum high temp paint on the inside, and flat black where it runs outside the frame in the rear.
Turning past the panhard bar mount on the outside of the frame
From inside the frame, running over the axle
The extra hole on the hanger will be cut off, and the round bar will be heated and bent around the pipe and tacked in a few places. I have three of these on each side
Bob
Old 06-24-2006, 01:46 AM   #25
Slammed66
Needs a Big Block
Slammed66's Avatar
Looks great , glad to see you workin on it again.!
One note on the muffler placement , I have them in the same place on my 64 , It creates alot of heat in the cab., and mine resonates like crazy ( flowmasters , you should need to worry about it)
Im in the process of moving them back to right onfront of the diff .
you might wanna thin about a heat sheild,
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
