06-21-2006, 03:09 PM | #1 |
carrier bearing failed
well going down the road my carrier bearing failed it was a replacement from o'reilys and of corse lost the ticket looking at buying a new one from advance auto i had the driveshaft balanced the last time i replaced it (octber/novmber) any ideas on getting these thing to last longer then 6 months?
06-21-2006, 03:20 PM | #2 |
Re: carrier bearing failed
Is it the horse-shoe or teardrop type? My truck has the teardrop one and I bought it from autozone about a year and a half ago, still works fine.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
06-21-2006, 03:59 PM | #3 |
Should last longer than that in a stockish truck. I replaced mine a year ago and the original one lasted 250k miles. If I went through one that fast Id look into getting a one piece shaft.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
06-21-2006, 04:15 PM | #4 |
its all about the +6 inches
I'd look somewhere else for a replacement. The chain stores have never impressed me with there junk driveline stuff.
Even a street/stri truck should be able to use a stock driveline and components. Knew a guy in Tx running 12's with a bone stock drive shaft set. Go to a driveline shop. A one piece shaft won't solve anything... if the bearing is broken becouse of a truck problem, then a one piece shaft will either just be a tem crutch, ot a ticking time bomb. Last edited by Longhorn Man; 06-21-2006 at 04:16 PM. |
06-21-2006, 04:29 PM | #5 |
i wasn't impressed by the how the part was i just went and picked one up from advance auto that seems stronger and better welded all around instead of just spot welds it is the tear drop one
06-21-2006, 05:14 PM | #6 |
Out of the carpool lane.
That's the problem with these crappy aftermarket bearings is that they end up spinning in the case and get destroyed. You're replacing them every 6 months which is a pain in the butt!!! Sure you can go with the Spicer poly bearings that are built like a tank, but you're going to pay just as much if not more when it's all said and done, than if you just get a 1 piece.
Go ahead and get yourself a 1-piece and never worry about that damn bearing ever again. I had one in my LWB for about 5 years and LOVED it. That was after replacing the bearing on a semi-annual and yearly basis.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
06-21-2006, 08:06 PM | #7 |
i dont really want ot go though the fabbing up a one piece i've looked into it once and noone will make one for this truck i've been happy with the 2 piece going to try this replacement bearing it seems strong then the last and going to go have the shaft checked again
06-21-2006, 09:25 PM | #8 |
If you had the shaft balanced its probably OK just make sure its clocked the same as when you took it apart. What I would check is to see if your trailing arm bushings are OK and that the rear yoke is directly inline with the trans output shaft. If this alighnment is off it will put a strain on the carrier bearing.
This alighnment can be adjusted with an adjustable panhard bar, thats why they are used when lowering a truck.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-21-2006, 09:32 PM | #9 |
umm okay my trucks not lowered
06-21-2006, 09:39 PM | #10 |
Firefighter
Go with a quality bearing like a BCA or Timken, that should help.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
06-21-2006, 10:55 PM | #11 |
I replaced my carier bearing and all the universals at the same time and was glad of it.
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
06-21-2006, 11:43 PM | #12 |
The one autozone sold me was the Timken brand. It still looks brand new, I'd see if they have one at the autozone where you are.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck Last edited by Robert1970C20rstbukt; 06-21-2006 at 11:44 PM. |
