Old 06-23-2006, 10:41 PM   #1
rchdrm
The start of the $ pit!
rchdrm's Avatar
How to guess size of a nut
I purchased a tilt colum from an individual on this site and after installing it I realized that it does not have the nut to hold the steering wheel on. Anyone got an idea about how and where to purchase one. I am guessing NAPA may have one but I am unsure what size and thread count. Help please. Thanks
rchdrm is offline   Reply With Quote
Old 06-23-2006, 10:43 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: How to guess size of a nut
is there a nut on your old column?
Old 06-24-2006, 12:26 AM   #3
jsbgump
Gone Fishing
jsbgump's Avatar
If I remember correctly it is 1/2 inch
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 06-24-2006, 01:00 AM   #4
krue
Designated A-hole!
krue's Avatar
I was thinking 5/8" fine thread.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 06-24-2006, 07:04 AM   #5
rchdrm
rchdrm's Avatar
The old column's nut didn't fit. It was too small. Bought a 5/8 and 1/2 inch fine thread's from Lowes and the 1/2 was too small and the 5/8 was too big.
I am thinking about wrapping the bolt in playdo, split the playdo off and take it to a bolt shop just wanted to see what ideas this group had.
Old 06-24-2006, 07:11 AM   #6
krue
Designated A-hole!
krue's Avatar
1/2 too little, 5/8 too small, do they make a 9/16's?
www.daveramsey.com
Old 06-24-2006, 10:07 AM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Yes a 9/16 x 12 and a 9/16 x 18 Most of the wheel nuts I've seen are fine thread.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-24-2006, 11:14 AM   #8
Smitty
Smitty's Avatar
9/16-18 would be the fine thread! But am not sure what size is required.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 06-24-2006, 11:41 AM   #9
toddtheodd
The oddest Todd around
toddtheodd's Avatar
mine was a 1/2 corse thread.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 06-24-2006, 02:06 PM   #10
mbgmike
They are usually 1/2"x16 and they are 1/4 inch thick. which makes it hard to find at a normal hardware store. We are out of them but Rez Engineering has them. The std 1/2" course thread is 13 tpi. We sell just about every bolt and nut to 5/8" but we are out of these.
mbgmike is offline   Reply With Quote
Old 06-24-2006, 02:14 PM   #11
wolfthing2000
sounds like a special thread, so you have to buy replacement part. Kinda like Harley in the old days had a 1/4-24 thread!
wolfthing2000 is offline   Reply With Quote
Old 06-24-2006, 04:42 PM   #12
mbgmike
The only other size it could be is a 9/16-18 which is 13/16 in across the flats and is a standard thread but not as as easy to find
but i measured a used one I have and it says 16 not 18 unless the threads have stretched on it. Its also 13/16" across flats A 1/2-13 bolt will not go through it and a std 9/16-12 is a course thread so it won't even start. So its either a 9/16-18 or in between and as you say may be special.
Old 06-24-2006, 05:16 PM   #13
john
member #16
john's Avatar
My tilt is 9/16' fine thread. The standard columns are 1/2' fine thread.
john is offline   Reply With Quote
Old 06-24-2006, 01:41 PM   #14
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If the wheel is off go to your local hardware store.Usually Lowes or HD has the bolt/nut guage.They are simply a plastic piece with holes and tabs whose sizes correspond to bolt and nut sizes.They can be hung on the wall or toolbox for easy access.They also come in metric and 'Mellican.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-24-2006, 06:51 PM   #15
Smitty
Smitty's Avatar
The only way to be sure of the threads is to use a thread pitch guage. It fits in the threads and will give you the number on the guage that fits. If I had a clue where mine might be I would check my spare tilt and know for sure.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Old 06-24-2006, 10:40 PM   #16
rchdrm
rchdrm's Avatar
It was a 9/16-18 and Lowes had one in stock. It is much thicker than needed but from what i am looking at it should not bother anything. Thanks for all the advice.
Old 06-24-2006, 10:46 PM   #17
mbgmike
Your lucky they had one. the oriiginal is more like a jamb nut. I went to the lowes and home depot around here (s houston) after your post to see if they had them now. And as usual they do not carry them at these locations I'm not sure the extra thickness would really be an issue. you just need to try it and see if it works for your wheel. We get them from coastal bolt.
Old 06-24-2006, 10:40 PM   #18
mbgmike
dun did that.
